Compiling difficulty for dynamicTopoFvMesh-port2.2.x in openfoam220
Like Tree2Likes
  • 2 Post By wyldckat
Old   January 4, 2014, 21:33
Default Compiling difficulty for dynamicTopoFvMesh-port2.2.x in openfoam220
Detian Liu
Detian Liu is on a distinguished road
Dear every one:
Recently I have a problem to compile dynamicTopoFvMesh-port2.2.x in openfoam220,I really need help from you!Thank you for the help!
the step for me to compile it like this:
1.
export MESQUITE_DIR=/opt/ThirdParty-2.2.0/mesquite-2.3.0
export MESQUITE_LIB_DIR=/opt/ThirdParty-2.2.0/mesquite-2.3.0/lib
2.
in the mesquite-2.3.0 folder, compile it as the install.txt
1)./configure --prefix=$MESQUITE_DIR --enable-release --disable-debug-assertions --disable-igeom --disable-imesh --disable-irel --enable-shared --without-cppunit --enable-trap-fpe --disable-function-timers
2)make
3)make install
there seems to be no problem, but when I try to compile dynamicTopoFvMesh-port2.2.x, I just input ./Allwmake in the dynamicTopoFvMesh-port2.2.x folder, but it gives the error like this:
+ [ 0 = 1 ]
+ ./AllwmakeLnInclude
+ wmakeLnInclude enginePointPatchFields
+ wmakeLnInclude mesquiteMotionSolver
+ wmakeLnInclude dynamicTopoFvMesh
+ cd fluxCorrector
+ wmakeLnInclude incompressible
+ wmake libso enginePointPatchFields
'/home/administrator/OpenFOAM/administrator-2.2.0/platforms/linux64GccDPOpt/lib/libenginePointPatchFields.so' is up to date.
+ wmake libso mesquiteMotionSolver
SOURCE=mesquiteMotionSolver.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/ThirdParty-2.2.0/mesquite-2.3.0/include -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/dynamicMesh/lnInclude  -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mesquiteMotionSolver.o
In file included from mesquiteMotionSolver.C:27:0:
mesquiteMotionSolver.H:83:9: error: ‘UpdateableMeshObject’ is not a member of ‘Foam’
mesquiteMotionSolver.H:85:5: error: wrong number of template arguments (3, should be 2)
/opt/openfoam220/src/OpenFOAM/lnInclude/MeshObject.H:52:7: error: provided for ‘template<class Mesh, class Type> class Foam::MeshObject’
mesquiteMotionSolver.C: In constructor ‘Foam::mesquiteMotionSolver::mesquiteMotionSolver(const Foam::polyMesh&)’:
mesquiteMotionSolver.C:71:9: error: ‘UpdateableMeshObject’ is not a member of ‘Foam’
mesquiteMotionSolver.C:73:5: error: wrong number of template arguments (3, should be 2)
mesquiteMotionSolver.C:62:1: error: uninitialized reference member ‘Foam::mesquiteMotionSolver::Mesh_’ [-fpermissive]
mesquiteMotionSolver.C:68:5: error: no matching function for call to ‘Foam::IOField<Foam::Vector<double> >::IOField()’
mesquiteMotionSolver.C:68:5: note: candidates are:
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:129:1: note: Foam::IOField<Type>::IOField(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Type> >&) [with Type = Foam::Vector<double>, Foam::IOobject = Foam::IOobject]
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:129:1: note:   candidate expects 2 arguments, 0 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:95:1: note: Foam::IOField<Type>::IOField(const Foam::IOobject&, const Foam::Field<Type>&) [with Type = Foam::Vector<double>, Foam::IOobject = Foam::IOobject]
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:95:1: note:   candidate expects 2 arguments, 0 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:61:1: note: Foam::IOField<Type>::IOField(const Foam::IOobject&, Foam::label) [with Type = Foam::Vector<double>, Foam::IOobject = Foam::IOobject, Foam::label = int]
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:61:1: note:   candidate expects 2 arguments, 0 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:31:1: note: Foam::IOField<Type>::IOField(const Foam::IOobject&) [with Type = Foam::Vector<double>, Foam::IOobject = Foam::IOobject]
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.C:31:1: note:   candidate expects 1 argument, 0 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.H:51:7: note: Foam::IOField<Foam::Vector<double> >::IOField(const Foam::IOField<Foam::Vector<double> >&)
/opt/openfoam220/src/OpenFOAM/lnInclude/IOField.H:51:7: note:   candidate expects 1 argument, 0 provided
mesquiteMotionSolver.C:73:6: error: expected ‘{’ before ‘(’ token
mesquiteMotionSolver.C: At global scope:
mesquiteMotionSolver.C:73:12: error: expected constructor, destructor, or type conversion before ‘,’ token
mesquiteMotionSolver.C:74:10: error: expected constructor, destructor, or type conversion before ‘(’ token
mesquiteMotionSolver.C: In constructor ‘Foam::mesquiteMotionSolver::mesquiteMotionSolver(const Foam::polyMesh&, const Foam::IOdictionary&)’:
mesquiteMotionSolver.C:119:9: error: ‘UpdateableMeshObject’ is not a member of ‘Foam’
mesquiteMotionSolver.C:121:5: error: wrong number of template arguments (3, should be 2)
mesquiteMotionSolver.C:109:1: error: uninitialized reference member ‘Foam::mesquiteMotionSolver::Mesh_’ [-fpermissive]
mesquiteMotionSolver.C:116:5: error: no matching function for call to ‘Foam::IOField<Foam::Vector<double> >::IOField()’
mesquiteMotionSolver.C:116:5: note: candidates are:
mesquiteMotionSolver.C:121:6: error: expected ‘{’ before ‘(’ token
mesquiteMotionSolver.C:121:12: error: expected constructor, destructor, or type conversion before ‘,’ token
mesquiteMotionSolver.C:122:10: error: expected constructor, destructor, or type conversion before ‘(’ token
/opt/ThirdParty-2.2.0/mesquite-2.3.0/include/TMetricBarrier.hpp:42:27: warning: ‘Mesquite2::barrier_violated_msg’ defined but not used [-Wunused-variable]
/opt/ThirdParty-2.2.0/mesquite-2.3.0/include/AWMetricBarrier.hpp:42:27: warning: ‘Mesquite2::barrier_violated_msg_aw’ defined but not used [-Wunused-variable]
make: *** [Make/linux64GccDPOpt/mesquiteMotionSolver.o] Error 1
+ wmake libso dynamicTopoFvMesh
SOURCE=dynamicTopoFvMesh.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/dynamicMesh/lnInclude -I/opt/openfoam220/src/dynamicFvMesh/dynamicFvMesh -I/opt/openfoam220/src/dynamicMesh/fvMeshDistribute -I/opt/openfoam220/src/parallel/decompose/decompositionMethods/lnInclude -I/opt/openfoam220/src/finiteVolume/lnInclude  -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/dynamicTopoFvMesh.o
dynamicTopoFvMesh.C: In member function ‘bool Foam::dynamicTopoFvMesh::resetMesh()’:
dynamicTopoFvMesh.C:4286:9: error: no matching function for call to ‘Foam::mapPolyMesh::mapPolyMesh(Foam::dynamicTopoFvMesh&, Foam::label&, Foam::label&, Foam::label&, Foam::labelList&, Foam::List<Foam::objectMap>&, Foam::labelList&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::labelList&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::labelList&, Foam::labelList&, Foam::labelList&, Foam::labelHashSet&, Foam::labelListList&, Foam::labelListList&, Foam::labelListList&, Foam::labelListList&, Foam::labelListList&, Foam::pointField&, Foam::labelList&, Foam::labelList&, Foam::autoPtr<Foam::Field<double> >&, bool)’
dynamicTopoFvMesh.C:4286:9: note: candidates are:
/opt/openfoam220/src/OpenFOAM/lnInclude/mapPolyMesh.H:318:9: note: Foam::mapPolyMesh::mapPolyMesh(const Foam::polyMesh&, Foam::label, Foam::label, Foam::label, Foam::labelList&, Foam::List<Foam::objectMap>&, Foam::labelList&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::labelList&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::labelList&, Foam::labelList&, Foam::labelList&, Foam::labelHashSet&, Foam::labelListList&, Foam::labelListList&, Foam::labelListList&, Foam::labelListList&, Foam::labelListList&, Foam::pointField&, Foam::labelList&, Foam::labelList&, bool)
/opt/openfoam220/src/OpenFOAM/lnInclude/mapPolyMesh.H:318:9: note:   candidate expects 28 arguments, 29 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/mapPolyMesh.H:286:9: note: Foam::mapPolyMesh::mapPolyMesh(const Foam::polyMesh&, Foam::label, Foam::label, Foam::label, const labelList&, const Foam::List<Foam::objectMap>&, const labelList&, const Foam::List<Foam::objectMap>&, const Foam::List<Foam::objectMap>&, const Foam::List<Foam::objectMap>&, const labelList&, const Foam::List<Foam::objectMap>&, const Foam::List<Foam::objectMap>&, const Foam::List<Foam::objectMap>&, const Foam::List<Foam::objectMap>&, const labelList&, const labelList&, const labelList&, const labelHashSet&, const labelListList&, const labelListList&, const labelListList&, const labelListList&, const labelListList&, const pointField&, const labelList&, const labelList&)
/opt/openfoam220/src/OpenFOAM/lnInclude/mapPolyMesh.H:286:9: note:   candidate expects 27 arguments, 29 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/mapPolyMesh.H:275:9: note: Foam::mapPolyMesh::mapPolyMesh(const Foam::mapPolyMesh&)
/opt/openfoam220/src/OpenFOAM/lnInclude/mapPolyMesh.H:275:9: note:   candidate expects 1 argument, 29 provided
make: *** [Make/linux64GccDPOpt/dynamicTopoFvMesh.o] Error 1
+ cd fluxCorrector
+ ./Allwmake
+ [ 0 = 1 ]
+ wmake libso incompressible
/usr/bin/ld: cannot find -ldynamicTopoFvMesh
collect2: ld returned 1 exit status
make: *** [/home/administrator/OpenFOAM/administrator-2.2.0/platforms/linux64GccDPOpt/lib/libincompressibleFluxCorrector.so] Error 1
Can someone give me some suggestions?
Thanks again for the kind help!
Detian
2014.1.5
Detian Liu is offline   Reply With Quote
Old   January 5, 2014, 09:17
Retired Super Moderator
Bruno Santos
Greetings Detian,
It's very likely because you are still using OpenFOAM 2.2.0. Several changes occurred since it was released. Try to update to OpenFOAM 2.2.2 or 2.2.x.
Best regards,
Bruno
Old   January 13, 2014, 07:03
Detian Liu
Dear Bruno,
Thanks for the help! I will have a try!
Best regards,
Detian
Old   January 13, 2014, 13:50
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Where is this port being hosted?
mturcios777 is offline   Reply With Quote
Old   January 13, 2014, 16:11
Bruno Santos
Greetings to all!
@Marco:
On the official (I think) repository by Sandeep Menon: https://github.com/smenon/dynamicTopoFvMesh
The port is on the respective branch: https://github.com/smenon/dynamicTop...ree/Port-2.2.x
Best regards,
Bruno
mturcios777 and Detian Liu like this.
difficulty with paraview compiling linch OpenFOAM Installation 10 October 14, 2010 07:28
