[OpenFOAM.com] Issues with installing v1712 on MacOS |
March 7, 2018, 15:04 |
Megan
Rep Power: 13 |
I have issues with the installation instructions for 1712. Has anyone installed this successfully on a mac running 10.11.6?
I get errors when sourcing in the bashrc and I'm not quite sure how to proceed. Thanks! |
March 7, 2018, 15:26 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
I'll have to be quick:
March 7, 2018, 15:28 |
Megan
Rep Power: 13 |
The official instructions for installing the source, do not seem to work for me on my mac 10.11.6. Are there specific instructions in http://openfoamwiki.net/index.php/Installation/Mac_OS
that I should be following? (it hasn't been updated with newer versions) Thanks! Oops never mind double posted!! Sorry! |
March 7, 2018, 15:38 |
Megan
Rep Power: 13 |
Great thanks!
I am installing from source because my mac is older and dockers will not work with it. So I have been following the instructions found here https://www.openfoam.com/download/install-source.php and then continuing with the build guide. the errors I see after attempting to source are: Daedalus:~ mnicholson$ source ~/OpenFOAM/OpenFOAM-v1712/etc/bashrc -bash: .: /Users/mnicholson/OpenFOAM: is a directory -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEval: command not found -bash: /Users/mnicholson/OpenFOAM: is a directory -bash: /Users/mnicholson/OpenFOAM: is a directory -bash: /Users/mnicholson/OpenFOAM: is a directory -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: _foamEtc: command not found -bash: /Users/mnicholson/OpenFOAM: is a directory -bash: /Users/mnicholson/OpenFOAM: is a directory -bash: /Users/mnicholson/OpenFOAM: is a directory -bash: .: /Users/mnicholson/OpenFOAM: is a directory Also as a note, I would prefer to install in /opt/ but I have been simply following the instructions as is to remove possible errors. I'm not really too sure what _foamEtc -mode=o prefs.sh _foamEtc -mode=ug prefs.sh are doing or why I am getting the warning about the directory (is it trying to create this folder again?) Thanks! |
March 7, 2018, 15:47 |
Bruno Santos
Rep Power: 128 |
Quick answer: The original OpenFOAM v1712 source code can only be built on Linux, that's why you're getting those errors.
The reason is very simple: Mac OS X is too different from Linux Distributions, which is why it needs several modifications in order to compilable from source code on Mac OS X. As I mentioned in the previous post, the official installation instructions for Mac OS X for OpenFOAM v1712 are available here: https://www.openfoam.com/download/in...binary-mac.php If you reaaaaaaally want to build from source code on Mac OS X, you will have to apply some modifications that are made available at this project: https://github.com/mrklein/openfoam-os-x/ ... er, wait... Alexey doesn't provide patches for OpenFOAM v1712... from that project, you would have to either pick the versions made available by the OpenFOAM Foundation, namely OpenFOAM-dev or OpenFOAM 5.x, instead of using OpenFOAM v1712 from OpenCFD.
Last edited by wyldckat; March 7, 2018 at 16:07. Reason: edited and then moved the edit to post #7 |
March 7, 2018, 16:04 |
Megan
Rep Power: 13 |
Seeing as dockers will not run on my machine (and I really don't like options like this) I guess I will either be using OpenFOAM 5.x or -dev. Thanks! This at least explains why it isn't working...I was also wondering why the requirements didn't list a mac os so now I know!
After looking through the commit for the patches I am almost inspired to apply similar fixes to 1712 (assuming the are not vastly different)...but you know my ample amount of free time will probably nix that idea. Thanks for the pointer!! |
March 7, 2018, 16:06 |
Bruno Santos
Rep Power: 128 |
My apologies, I was too quick to read at first and happened to quickly re-read your previous post while checking my emails.
Still, as I mentioned in the post, you could try building from source code OpenFOAM 5.x or dev, by using Alexey's patches at https://github.com/mrklein/openfoam-os-x/ - see the wiki pages for more details: https://github.com/mrklein/openfoam-os-x/wiki The only other solution I'm aware of for Mac OS X is to use VirtualBox or Parallels to create a virtual machine with a Linux Distribution installed inside, and then build/run OpenFOAM inside that virtual machine. |
April 12, 2018, 17:07 |
#8 | |
Mark Olesen
Rep Power: 40 |
/mark |
April 12, 2018, 17:44 |
#9 | |
Mark Olesen
Rep Power: 40 |
The _foamEtc commands are short wrappers for using the OpenFOAM foamEtcFile script to locate configuration files and then source them. The -mode options follow the usual user/group/other naming that you may be familiar with from the "chmod" command. Except for OpenFOAM the 'user' means searching under your ~/. OpenFOAM/ directory. The 'group' means searching under $WM_PROJECT_SITE directory. And 'other' means searching under the $WM_PROJECT_DIR/etc/ directory (ie, the OpenFOAM installation). The prefs.sh file is simply a preferences file that can be used to provide configuration values without editing the bashrc file and either forgetting what you've changed, or forgetting what to do at the next version upgrade. So in the first call, with -mode=o, a prefs.sh file from the main etc/ directory is searched. This means that a cluster admin can generate this file and be certain that it will be used (eg, defining particular compiler choices, or extra stuff for mpi). The next call, with -mode=ug, will first try to find a prefs file from the hidden directory in your $HOME, or from the shared group directory where one of your coworkers may have been friendly enough to provide tweaks local to your simulation group. The combination of both should give enough reliability for admins while still leaving plenty of room for the user to make further adjustments. This may make more sense if you consider multi-user installations where OpenFOAM is installed without write permissions for the normal user. /mark |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Installing ANSYS Linux 64bit, on MacOS? | Ash Kot | ANSYS | 1 | December 17, 2020 22:13 |
[waves2Foam] A few notes about problems and solutions when installing with OpenFOAM v1712 | oceanFoam | OpenFOAM Community Contributions | 0 | June 22, 2018 08:52 |
[OpenFOAM.com] Installing OpenFoam on macOS High Sierra | Mathematikus20 | OpenFOAM Installation | 1 | December 30, 2017 09:04 |
Issues installing paraVeiw/paraFoam | Creul91 | OpenFOAM Installation | 1 | October 4, 2014 13:05 |
