Error: Current directory is not $WM_THIRD_PARTY_DIR
Old   August 28, 2014, 05:00
Default Error: Current directory is not $WM_THIRD_PARTY_DIR
Steve
lapsednun is on a distinguished road
Hello. Getting V. frustrated! Assume that my environment variables must be at fault but can't see what the issue is however several hours of head banging later....
I'm a bit of a newbie at this so it's probably blindingly obvious what's wrong to those of you who know what you're doing!
So. I'm attempting to compile into /opt/OpenFOAM/OpenFOAM-2.3.0 On an Ubuntu 14.04 VM. When I run ./Allwmake from the ThirdParty-2.3.0 folder I get the error:
./Allwmake: 34: ./Allwmake: wmakeCheckPwd: not found
    The environment variables are inconsistent with the installation.
    Check the OpenFOAM entries in your dot-files and source them.
I currently have set:
root@swilley-w7:/opt/OpenFOAM/OpenFOAM-2.3.0/ThirdParty-2.3.0# echo $WM_THIRD_PARTY_DIR
/opt/OpenFOAM/ThirdParty-2.3.x
root@swilley-w7:/opt/OpenFOAM/OpenFOAM-2.3.0/ThirdParty-2.3.0# echo $FOAM_INST_DIR
/opt/OpenFOAM
root@swilley-w7:/opt/OpenFOAM/OpenFOAM-2.3.0/ThirdParty-2.3.0# echo $WM_PROJECT_DIR
/opt/OpenFOAM/OpenFOAM-2.3.x
bashrc file is attached.
Any help/suggestions much appreciated!
thanks
Steve
lapsednun is offline   Reply With Quote
Old   August 30, 2014, 10:46
Retired Super Moderator
Bruno Santos
Greetings Steve and welcome to the forum!
The problem seems to be that you have more than one OpenFOAM version already installed, most likely version 2.3.x, which is why the environment variables for the other version are colliding with 2.3.0.
Here is some reading material on this topic: http://openfoamwiki.net/index.php/In...with_the_Shell
Best regards,
Bruno
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
