[Other] [openSUSE] installed but not running
Old   November 6, 2014, 05:45
Default [openSUSE] installed but not running
a
minaret is on a distinguished road
Hi
I installed it on openSUSE operating system. but when I try to run some examples, like cavity, it doesnt run.
before I say some examples, I hasten to add that surely it is installed. because when I tried to install it again, the massage appeared that it is already installed.
now 2 examples:
1. when I write in the terminal:
gedit ~/.bashrc
this message appears:
If 'gedit' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf gedit
2.when I try to run blockMesh in the cavity folder, this message appears:
If 'blockMesh' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf blockMesh
what should I do?
thanks.
minaret is offline   Reply With Quote
Old   November 7, 2014, 15:20
eangola is on a distinguished road
Originally Posted by minaret View Post
Hi
now 2 examples:
gedit ~/.bashrc
cnf gedit
cnf blockMesh
what should I do?
thanks.
Seems like you don't have gedit for starters. write this on the terminal
which -a gedit
should return something like
/usr/bin/gedit
try also
gedit --version
which should return the version of gedit installed.
If you don't have gedit type the following on terminal
sudo apt-get update
sudo apt-get install gedit
eangola is offline   Reply With Quote
Old   November 8, 2014, 00:21
Default thaaaaaaaaanks...
a
which -a gedit
/usr/bin/gedit
try also
gedit --version
sudo apt-get update
thank you
thank you
you rescued me!
but I should amend one thing in your codes:
it seems that "apt-get" is not included in SUSE operating system.
instead there is "zypper"
I used these in terminal - Super User Mode:
zypper update
zypper in gedit
and it did what I wanted
(thank you a lot. because it is quite long time that I'm trying to install openfoam on my laptop. I tried Ubunto. but ubunto didn't get installed on my laptop. so I tried openSUSE and after all you helped me. thanks.)
installed, not run
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 13:30
icoFoam won't run while Paraview is running MikeHersee OpenFOAM Running, Solving & CFD 2 January 6, 2015 05:06
running without rsh between nodes hattonps OpenFOAM 10 March 22, 2010 15:02
What do you CFD guys do during a long simulation running? bearcat Main CFD Forum 5 July 23, 2009 08:08
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
