[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 in Ubuntu 14.04
Old   November 5, 2014, 09:49
Default Problems installing OpenFOAM 2.3.0 in Ubuntu 14.04
iafpython's Avatar
Igor
iafpython is on a distinguished road
I would like to know (I am very new to all these) if I did install well OpenFOAM in my ubuntu 14.04 (OS) laptop.
I have followed the instructions here
http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04
Thank you,
iaf
iafpython is offline   Reply With Quote
Old   November 5, 2014, 20:41
lynzhung
lynzhung is on a distinguished road
Maybe you can see the official web , where it show how to check in ubuntu 13.10 .etc
lynzhung is offline   Reply With Quote
Old   November 5, 2014, 20:44
iafpython's Avatar
Igor
Thank you lynching! I'll do it, though I already ran the cavity test case and something is wrong, there are errors in the polymesh file.
Old   November 5, 2014, 20:45
iafpython's Avatar
Igor
Sorry, lynzhung! the spell checker !
Old   November 7, 2014, 15:59
Default error running "cavity" tutorial case
iafpython's Avatar
Igor
I've just installed OpenFOAM and ran the tutorial case cavity.
Something is not working good, and I need some help to know what should I do.
Here is the message I get:
 iaf@iaf-Inspiron-5520:~/OpenFOAM/OpenFOAM-2.3.0/tutorials/incompressible/icoFoam/cavity$ icoFoam
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0-f5222ca19ce6
Exec   : icoFoam
Date   : Nov 07 2014
Time   : 16:27:22
Host   : "iaf-Inspiron-5520"
PID    : 4072
Case   : /home/iaf/OpenFOAM/OpenFOAM-2.3.0/tutorials/incompressible/icoFoam/cavity
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "polyMesh" in times 0 down to constant
    From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
    in file db/Time/findInstance.C at line 203.
FOAM exiting
Old   November 8, 2014, 05:02
Retired Super Moderator
Bruno Santos
Greetings to all!
@Igor: I moved your latest post to this thread, because the two topics are related.
Now, for the initial question and for which you had also sent me a private message, you can attach the file "make.log.tar.gz" to your next post, so that I can have a look into it.
As for the latest question, the problem is that either you didn't run blockMesh first, or blockMesh simply didn't work. I suggest that you follow more carefully the tutorials chapter in the OpenFOAM User Guide: http://www.openfoam.org/docs/user/tutorials.php
Last but not least: my guess is that the installation went well, it's just that you weren't following the User Guide
Best regards,
Bruno
Old   November 10, 2014, 10:14
Default Re:
iafpython's Avatar
Igor
@Bruno
Thank you very much Bruno.
I've attached the file, I surely will follow your advice, and let you know how it goes!
Old   November 10, 2014, 16:27
Bruno Santos
Quick answer:
There are no errors in the file you attached. Everything should work properly. Keep in mind that OpenFOAM is all about the details.
Old   November 10, 2014, 16:43
iafpython's Avatar
Igor
Thanks again Bruno!
[OpenFOAM.org] Problems installing OpenFOAM 2.4.0 on Ubuntu 16.04 donminoti OpenFOAM Installation 13 January 13, 2021 17:07
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on CentOS-6.6-x86-64 Milan2013 OpenFOAM Installation 24 November 28, 2015 15:05
[OpenFOAM.org] Installing OpenFOAM 2.3.x on Ubuntu 14.04 samiam1000 OpenFOAM Installation 4 January 26, 2015 02:44
[OpenFOAM.org] (Script)OpenFOAM 2.3.0 and Paraview for Ubuntu 14.04 p0kerus OpenFOAM Installation 2 December 2, 2014 07:54
Prolem installing OpenFOAM Ver 2.3.0 source in Ubuntu 13.1.0 on VMware zandi OpenFOAM Installation 5 March 31, 2014 03:57
