[OpenFOAM.org] OpenFOAM 2.3.0 Installation Problem on CentOS 6.6 |
November 6, 2014, 03:42 |
Yu-sen Niu
Rep Power: 11 |
Hello everyone!
Recently I'm installing OpenFOAM 2.3.0 on CentOS6.6, and it's a Virtual Machine built by VMware 10. According to the guide of source installation, I have installed gcc, openmpi and everything. Before beginning installation I checked their version by executing cmd in the terminal like this: $gcc --version $mpirun --version And everything is OK, it shows gcc 4.7.2 and mpirun (Open MPI) 1.8.1. Following the guide I added these words into .bashrc: source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc then I executed cmd: $source .bashrc No errors are reported, but when I check the version of mpirun again, the problem occured. After I entered cmd $mpirun --version, it showed words as follow. ----------------------------------------------------------------- Sorry! You were supposed to get help about: opal_init:startup:internal-failure But I couldn't open the help file: /home/shenzhou1987/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/share/openmpi/help-opal-runtime.txt: No such file or directory.Sorry! ----------------------------------------------------------------- I don't know whether it's OK.And if I remove 'source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc' from file .bashrc, it will not appear. But in order to install OpenFOAM, I have to add these words into .bashrc. Then I execute './Allwmake' in folder 'OpenFOAM-2.3.0', and during the installation a warning message is reported as follow. checking whether PMPI is enabled... no configure: WARNING:*************************************** configure: WARNING:***VampirTrace cannot be built due to disabled MPI profiling. configure: WARNING:***Pausing to give you time to read this message... configure: WARNING:*************************************** So I don't know whether it will affect the installation or not. Can anybody give me some advice? Thank you. |
December 14, 2014, 13:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings shenzhou1987 and welcome to the forum!
Sorry for the really late reply, but I only managed to test the following (unofficial) instructions on CentOS 6.6 last week and they worked just fine: http://openfoamwiki.net/index.php/In...HEL#CentOS_6.5 This to say that the problems you're witnessing are probably due to 2 possible situations:
Best regards, Bruno
[Other] OpenFoam installation on CentOS 7 32 bits | donminoti | OpenFOAM Installation | 3 | January 31, 2016 06:19 |
[OpenFOAM.org] Installation of OpenFOAM 2.3.0 on SSH RHEL 6.2 Santiago | jyang1 | OpenFOAM Installation | 6 | August 26, 2015 18:47 |
[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS | mukut | OpenFOAM Installation | 9 | January 19, 2015 00:48 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
