[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS
Like Tree1Likes
  • 1 Post By mukut
Old   January 9, 2015, 23:58
Exclamation Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS
Mominul MuKuT
mukut is on a distinguished road
Dear FOAMers!
Recently I have installed OpenFOAM 2.3.1, earlier I have used version 2.1.1
After installation of openfoam 2.3.1, when I run e terminal following error message displayed in terminal:
PHP Code:
ccerrorunrecognized command line option ‘--showme:link’
I have checked here (http://www.openfoam.org/download/ubuntu.php) under INSTALLATION PROBLEM.
when I ran the command:
PHP Code:
sudo update-alternatives --list mpi
in the terminal following appeard
PHP Code:
/usr/include/lam
/usr/include/mpich
Then according to suggestion of the link given above: when I ran the command
PHP Code:
sudo update-alternatives --set mpi /usr/lib/openmpi/include
following error appeared
PHP Code:
update-alternativeserroralternative /usr/lib/openmpi/include for mpi not registerednot setting
How to solve this issue?
BR
mukut
pfguo likes this.
mukut is offline   Reply With Quote
Old   January 10, 2015, 15:50
Retired Super Moderator
Bruno Santos
Greetings mukut,
A few questions:
  1. Which installation instructions did you follow to install OpenFOAM 2.3.1?
  2. Did you uninstall OpenFOAM 2.1.1? If you did, then what steps did you perform?
Best regards,
Bruno
Old   January 11, 2015, 01:33
Mominul MuKuT
Thanks Mr. Bruno!
Ans for 1st Q: I am using these steps to install openFOAM 2.3.1: https://www.youtube.com/watch?v=LkLgwm64jGI
ans for 2nd Q: I just deleted openFOAM 2.1.1 folder.....
I have informed the youtuber who has given the tutorial regarding my issue: he replied as follows:
PHP Code:
If you followed the instructions of the videothe openmpi path should be
/home/sharials/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/include
You just have to exchange 'sharials' for your username.
Now you run:
sudo update-alternatives --list mpi /home/YOUR_NAME_HERE/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/include
Hope that helps!
So when I ran the command as he mentioned in the reply in my terminal error showed as follows:
PHP Code:
mukut@mukut-Endeavor-MR3300:~$ sudo update-alternatives --list mpi /home/mukut/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/include
sudopassword for mukut
update-alternativeserrorunknown argument `/home/mukut/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/openmpi-1.6.5/include'
What should I do?
Regards
mukut
Old   January 11, 2015, 02:01
Mominul MuKuT
Dear Mr. Bruno!
Shall I have to install the OF and then a fresh installation? I am waiting for your reply.
I have ran a case, it works fine. After comparing results, I will inform you.
Actually what is the effect due to show link cc error???
BR
mukut
Old   January 11, 2015, 02:03
Default Hi
p0kerus is on a distinguished road
Hi Mukut;
You need to see if these files are installed
sudo apt-get install libopenmpi-dev openmpi-bin
As i can see you have two mpi installed you have to make symbolic link to ensure correct global mpi
ln -s /usr/bin/mpicc.openmpi OpenFOAM-2.3.0/bin/mpicc
ln -s /usr/bin/mpirun.openmpi OpenFOAM-2.3.0/bin/mpirun
And if you have still have error follow this guide https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04
Or you can use prebuild openfoam installtion script that i have posted on forum.
Regards;
p0kerus
p0kerus is offline   Reply With Quote
Old   January 11, 2015, 03:38
Mominul MuKuT
Dear Mr. p0kerus!
Thanks a lot!
After running your 1st command in terminal, the installation completed by download file.
Then I run 2nd two commands in the terminal:
mukut@mukut-Endeavor-MR3300:~$ ln -s /usr/bin/mpicc.openmpi OpenFOAM-2.3.1/bin/mpicc
ln: failed to create symbolic link ‘OpenFOAM-2.3.1/bin/mpicc’: No such file or directory
Anyway, after that I have closed the terminal and open again but there is no error as I posted here.
Does it really solve?
Regards
mukut
Old   January 11, 2015, 12:56
Bruno Santos
Greetings to all!
FYI: Instructions for compiling OpenFOAM 2.3.1 on Ubuntu 14.04 have been available on the wiki since at least the 31st of December of 2014: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04 - therefore, there is no need to go around trying to manually replace occurrences of "2.3.0" by "2.3.1".
@mukut: It seems that you jumped from some other step directly to step #5. Please follow the steps in the correct order (from 1 to 12), in order for them to work as expected.
Best regards,
Bruno
Old   January 12, 2015, 00:55
Mominul MuKuT
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Thanks a lot Mr. Bruno.
After p0kerus reply, the show link error didn't show in terminal and I am using openFoam. In this situation, I need your suggestion. Shall I continue to use openFOAM or uninstall it and then use the steps to install that the link you have given in last reply?
Regards
mukut
Old   January 18, 2015, 14:55
Bruno Santos
Hi mukut,
If your OpenFOAM installation is now working, then no need to rebuild it again. Feel free to use it as it is.
Either way, if you see one or more situations where you think that something might be broken in your installation, then perhaps it's best to remove the current installation and start over.
Best regards,
Bruno
Old   January 19, 2015, 00:48
Mominul MuKuT
Hi mukut,
Best regards,
Bruno
Dear Mr. Bruno
Thank you so much. OF works fine, thanks again
cc error, installation issue, openfoam 2.3.x
[OpenFOAM.org] Problem during installation of openfoam 2.3.0 on ubuntu 16.04 jarvis OpenFOAM Installation 2 March 20, 2018 08:32
[OpenFOAM.org] Problem Installing OpenFOAM V 2.3.1 in Ubuntu 17.04 tareqkh OpenFOAM Installation 1 September 2, 2017 10:10
[OpenFOAM.org] Ubuntu 14.04 LTS OpenFoam 4.1 Installation Error behzad-cfd OpenFOAM Installation 2 March 5, 2017 02:44
[OpenFOAM.org] OpenFoam 3.0 installation on Ubuntu 14.04.3 tab2001ng OpenFOAM Installation 3 March 8, 2016 01:38
[OpenFOAM.org] OpenFOAM 2.4.x installation script for ubuntu p0kerus OpenFOAM Installation 0 June 1, 2015 15:52
