April 23, 2015, 06:58 |
OpenFOAM compilation error
Marco Conte
I am trying to compile OpenFOAM 2.3.1 and my OS is OpenSUSE 13.2, I have run foamSystemCheck and all seems OK, but when I run Allwmake several errors occour. Errors looks like :
collect2: error: ld returned 1 exit status /opt/OpenFOAM/OpenFOAM-2.3.1/wmake/Makefile:149: recipe for target '/opt/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/checkMesh' failed make: *** [/opt/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/checkMesh] Error 1 Ho can fix this ? |
April 23, 2015, 16:00 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Marco and welcome to the forum!
I strongly advise you to first build OpenFOAM as a normal user and not as root. Nonetheless, I'm guessing something didn't go very well when you started working in root mode, so I suggest you read/study this page: http://openfoamwiki.net/index.php/In...with_the_Shell Beyond this, detailed instructions for building OpenFOAM 2.3.1 on openSUSE 13.2 are available here: http://openfoamwiki.net/index.php/In...#openSUSE_13.2 Best regards, Bruno
April 24, 2015, 12:37 |
#3 | |
Marco Conte
Regards, Marco |
Compilation Error | vizvaz | Fluent UDF and Scheme Programming | 2 | January 6, 2017 04:19 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
