[OpenFOAM.com] v1612+ on Win10 - Pemission Denied Issues
Old   February 9, 2017, 17:42
Default v1612+ on Win10 - Pemission Denied Issues
highorder_cfd is on a distinguished road
Hi, I have installed OPENFoam in Win10 running as administrator. Now I am getting errors even using mkdir ... what should I do to get it up and running?
Many thanks
Originally Posted by khedar View Post
There seems to be an issue with permission? Is your account an admin account or did you install as an admin?
I say this because the first lines in you attached photo is related to access denied for some registry key.
highorder_cfd is offline   Reply With Quote
Old   February 10, 2017, 06:06
Default [OpenFOAM plus] [v1612+] on Win10 - Pemission Denied Issues
Hi
I am completely new to OpenFoam. I have installed this on windows10 and installation went well. However I have realized that basically I am not allowed to do any operation in the OpenFoam directories, e.g. if I use mkdir or cp command I get a permission denied error. Any suggestion?
By the way, I have installed OpenFoam in a Docker container "running as administrator". Can this be the issue?
Thanks
Old   February 11, 2017, 18:28
Ok, my fault. It looks like there are no issues in the installation.
For future reference, the OpenFoam directory can be edited logging in as root (password reported in the pdf manual).
Tutorials must be copied to workDir to be run, e.g.
cd workingDir
cp -ar $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity .
cd cavity
blockMesh
icoFoam
Old   February 20, 2017, 17:49
Retired Super Moderator
Bruno Santos
Quick questions, to make it easier to understand the context of your posts:
  1. Which specific version of OpenFOAM are you referring to?
  2. Which installation instructions did you follow?
Old   February 21, 2017, 07:17
I have installed OpenFOAM v1612+ Released inside Docker on Win10,
following http://www.openfoam.com/download/ins...ry-windows.php
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 16:18
