[swak4Foam] Swak4foam installation for OF 3.0.1 |
February 24, 2016, 09:15 |
Gregor Alan
Rep Power: 10 |
Hi all,
I am trying to install swak4foam2.x on ubuntu with OpenFOAM 3.0.1. I have an error message when running ./Allwmake after ./Allwclean. I do not know how to fix this. Code:
This is a clean install /home/gregor/OpenFOAM/gregor-3.0.1/swak4Foam_2.x/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) No file 'swakConfiguration'. Python etc won't work. See README for details Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems Checking swak4Foam-version and generating file abort: no repository found in '/home/gregor/OpenFOAM/gregor-3.0.1/swak4Foam_2.x' (.hg not found)! Swak version is 0.3.2 Bison is version 2.7.12-4996 Flex is version 2.5.35 (Minor version: 35) OpenFOAM-version: Major 3 Minor 0 Patch 1 (-1 == x / 1) No swak4FoamParsers/foamVersion4swak.H. Generated wmakeLnInclude: linking include files to simpleFunctionObjects/lnInclude make: *** No rule to make target `Make/linux64GccDPInt32Opt/SubsetValueExpressionParser.o', needed by `Make/linux64GccDPInt32Opt/CellSetValueExpressionDriver.o'. Stop. wmake error: file 'Make/linux64GccDPInt32Opt/sourceFiles' could not be created in /home/gregor/OpenFOAM/gregor-3.0.1/swak4Foam_2.x/Libraries/swak4FoamParsers Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard Kind regards, Gregor |
February 27, 2016, 09:52 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions:
March 14, 2016, 07:59 |
noori
Rep Power: 10 |
I have same above problem.
I am using from openfoam with version 3.0.1 and version ubuntu 14.04, Unfortunately, during installation swak4Foam error is as follows: Code:
No 'swakConfiguration'. Python etc won't work Checking swak4Foam-version and generating file Swak version is 0.2.4 Bison is version 3.0.2 Flex is version 2.5.35 (Minor version: 35) OpenFOAM-version: Major 3 Minor 0 Patch 1 (-1 == x) No swak4FoamParsers/foamVersion4swak.H. Generated g++ -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linuxGccDPInt32Opt -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/sampling/lnInclude -I/opt/openfoam30/src/fileFormats/lnInclude -I/opt/openfoam30/src/triSurface/lnInclude -I/opt/openfoam30/src/surfMesh/lnInclude -I/opt/openfoam30/src/lagrangian/basic/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c helpers/printSwakVersion.C -o Make/linuxGccDPInt32Opt/helpers/printSwakVersion.o g++ -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linuxGccDPInt32Opt -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/sampling/lnInclude -I/opt/openfoam30/src/fileFormats/lnInclude -I/opt/openfoam30/src/triSurface/lnInclude -I/opt/openfoam30/src/surfMesh/lnInclude -I/opt/openfoam30/src/lagrangian/basic/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/SurfacesRepository.C -o Make/linuxGccDPInt32Opt/repositories/SurfacesRepository.o g++ -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linuxGccDPInt32Opt -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/sampling/lnInclude -I/opt/openfoam30/src/fileFormats/lnInclude -I/opt/openfoam30/src/triSurface/lnInclude -I/opt/openfoam30/src/surfMesh/lnInclude -I/opt/openfoam30/src/lagrangian/basic/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/MeshesRepository.C -o Make/linuxGccDPInt32Opt/repositories/MeshesRepository.o Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Last edited by wyldckat; March 19, 2016 at 16:10. Reason: merged posts that were a few minutes apart |
March 19, 2016, 16:23 |
Bruno Santos
Rep Power: 128 |
Greetings noori and welcome to the forum!
Please go into the swak4Foam folder and run the following commands: Code:
./maintainanceScripts/compileRequirements.sh ./Allwmake > make.log 2>&1 gzip < make.log > make.log.gz Best regards, Bruno
May 30, 2016, 10:22 |
R. P.
Rep Power: 15 |
Hi Bruno,
I am having some problem during the compilation. Please, find attached the log files Thanks. make.log.gz |
June 26, 2016, 12:36 |
Rep Power: 10 |
Hi guys,
Was there a follow up on this ? Im facing the some trouble ! Thanks |
September 17, 2016, 07:01 |
#7 | |
Bruno Santos
Rep Power: 128 |
./maintainanceScripts/compileRequirements.sh Code:
./maintainanceScripts/compileRequirements.sh > log.makeReq 2>&1 gzip < log.makeReq > log.makeReq.gz In addition, I need to know which Linux Distribution you're using. ---- I need more details, as mentioned above.
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM | steven123 | OpenFOAM Community Contributions | 35 | January 11, 2021 16:53 |
[swak4Foam] [OpenFOAM plus] [v1612+] swak4Foam installation problem in Windows (Allwmake) | LThomes | OpenFOAM Community Contributions | 7 | October 6, 2020 13:36 |
[OpenFOAM.org] icoFoam: Command not found in OpenFOAM 3.0.1 installation on Ubuntu 16.10 | febriyan91 | OpenFOAM Installation | 2 | July 27, 2020 00:23 |
[swak4Foam] swak4Foam 0.3.1 OF2.2.2 Installation Issue | scnsc | OpenFOAM Community Contributions | 3 | August 20, 2014 07:59 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 13:00 |
