[OpenFOAM.org] openfoam 2.4.0 installation
Old   September 27, 2016, 13:58
Default openfoam 2.4.0 installation
ali
abdoli is on a distinguished road
hi friends
i am new user of openfoam. i want to install openfoam 2.4.0 on ubuntu 14.4 . i followed instruction in https://openfoamwiki.net/index.php/I...M-2.4.0/Ubuntu. but it give the attached error log file. could any one help me.
thanks a lot
abdoli
abdoli is offline   Reply With Quote
Old   September 29, 2016, 15:52
Retired Super Moderator
Bruno Santos
Quick answer: Either you didn't run the complete command that is shown in the wiki page, namely the "2>&1" part might be missing in the command you ran:
./Allwmake > log.make 2>&1
Or you accidentally hit the key combination Ctrl+C, which aborted the build.
Either way, please run the command above once again.
Old   September 30, 2016, 02:05
ali
dear Bruno
thank you for reply. i am installing openfoam 2.4.0 as second foam. i have foam-extend 3.1 now on ubuntu 14.04. i will do your suggestion and inform you. i have another problem with 'wmake' command and install swake4Foam. when i type wmake it gives 'wmake: command not found'. i followed https://openfoamwiki.net/index.php/I...14.04_to_15.10 for installing
swake4Foam. but it gives attached error log file. how can i fix it?
thanks a lot
Ali
File Type: gz log.make.tar.gz (507 Bytes, 1 views)
Old   October 6, 2016, 15:44
Bruno Santos
Originally Posted by abdoli View Post
dear Bruno
thanks a lot
Ali
Quick answer: You forgot to activate the OpenFOAM or foam-extend shell environment. You should either run of240 or fe31 or whichever alias you are using.
For more details, please read: http://openfoamwiki.net/index.php/In...nFOAM_versions
I have moved your two other posts to there: http://www.cfd-online.com/Forums/ope...m-2-4-0-a.html
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 15:54
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 11:43
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 Nait OpenFOAM Installation 2 December 12, 2012 10:20
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 02:15
