[OpenFOAM.com] v1606+ compiling problem with 64-bit labels
Old   October 19, 2016, 13:15
Default v1606+ compiling problem with 64-bit labels
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hello Foamers,
I m stuck with a wierd error while compiling Openfoam-v1606+ . I m compiling OF1606+ on CENTOS 7.2 in /opt folder.
Everything went well untill the last Openfoam compilation. Now I get this error:
error: No matching function to call for »Foam::turbulentDFSEMInletFvPatchVectorField::writeEntryIfDifferent(Foam::Ostream&, const char [13], int, const label&) const«
     writeEntryIfDifferent(os, "nCellPerEddy", 5, nCellPerEddy_);
fields/fvPatchFields/derived/turbulentDFSEMInlet/turbulentDFSEMInletFvPatchVectorField.C:1110:63: note: candidate is:
In file included from lnInclude/fixedValueFvPatchField.H:58:0,
                 from lnInclude/fixedValueFvPatchFields.H:29,
                 from fields/fvPatchFields/derived/turbulentDFSEMInlet/turbulentDFSEMInletFvPatchVectorField.H:83,
                 from fields/fvPatchFields/derived/turbulentDFSEMInlet/turbulentDFSEMInletFvPatchVectorField.C:26:
lnInclude/fvPatchField.H:533:18: Anmerkung: template<class EntryType> void Foam::fvPatchField<Type>::writeEntryIfDifferent(Foam::Ostream&, const Foam::word&, const EntryType&, const EntryType&) const [with EntryType = EntryType; Type = Foam::Vector<double>]
             void writeEntryIfDifferent
lnInclude/fvPatchField.H:533:18: note:   template argument deduction/substitution failed:
fields/fvPatchFields/derived/turbulentDFSEMInlet/turbulentDFSEMInletFvPatchVectorField.C:1110:63: note:  deduced conflicting types for parameter ‘const EntryType’ (‘int’ and ‘Foam::label {aka long int}’)
make: *** [/opt/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt64Opt/src/finiteVolume/fields/fvPatchFields/derived/turbulentDFSEMInlet/turbulentDFSEMInletFvPatchVectorField.o] error 1
FYI: I read the post http://www.cfd-online.com/Forums/ope...-problems.html #17
I previously installed OF1606+ in Home/User directory with "Lable size 64" on another computer with the same centOS 7.2 and it worked fine. But other users could not access openFoam for that reason I wanted to install OF1606 this time in a system wide location (opt).
I m lost at this point. Please through some light. Thank you in advance.
Best Regards,
Naresh
Naresh yathuru is offline   Reply With Quote
Old   October 20, 2016, 09:02
Joost
JD1995 is on a distinguished road
Hey Naresh,
I have got exactly the same error while compiling OFv1606+ on Ubuntu, so maybe there is some change in a code?
Hope someone can help us out.
Best regards,
Joost
Here is my error:
make: *** [/home/ubuntu/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt64Opt/src/finiteVolume/fields/fvPatchFields/derived/turbulentDFSEMInlet/turbulentDFSEMInletFvPatchVectorField.o] Error 1
JD1995 is offline   Reply With Quote
Old   October 22, 2016, 04:19
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
This was fixed quite sometime ago. You should try the master branch from develop.openfoam.com
olesen is offline   Reply With Quote
Old   October 24, 2016, 14:35
Naresh Yathuru
Hi everyone
I followed the tip suggested in the main post by Bruno. It worked.
which is : I changed the 64 label size to 32 in the /OpenFoam/OpenFOAM-v1606+/etc/bashrc file.
Thank you
Regards,
Naresh
Old   November 17, 2016, 22:29
QuocThien
neiht is on a distinguished road
Choose:
source $HOME/OpenFOAM/OpenFOAM-v1606+/etc/bashrc
instead of:
source $HOME/OpenFOAM/OpenFOAM-v1606+/etc/bashrc WM_LABEL_SIZE=64
neiht is offline   Reply With Quote
[OpenFOAM.org] Creepy ugly problem in compiling ParaView 4.4.0 for OF 3.0.x Democritus OpenFOAM Installation 1 June 23, 2016 23:11
problem with compiling udf through visual studio chem engineer Fluent UDF and Scheme Programming 2 August 17, 2015 10:46
problem with compiling boundary condition udf in parallel mode chem engineer Fluent UDF and Scheme Programming 11 June 29, 2015 06:23
problem compiling spalart allmaras model bababanamzdaalma OpenFOAM 0 April 4, 2012 20:13
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
