[OpenFOAM.org] Error in installing OF211 on ubuntu 16.10
Like Tree6Likes
  • 1 Post By wyldckat
  • 2 Post By vitormoura
  • 3 Post By wyldckat
Old   December 11, 2016, 04:55
Default Error in installing OF211 on ubuntu 16.10
Kasra
k.farnagh is on a distinguished road
Hi everybody,
I've applied installation guide which exists in
http://openfoam.org/download/2-1-1-source/
It should be mentioned the GCC version of ubuntu 16.10 is 6.2 but in below link noted that is not supported for OF211.
http://openfoamwiki.net/index.php/In...ibility_Matrix
A attached file is provided to diagnose the building process and errors.
Would you please guide me to solve them.
Sincerely Yours
Kasra
k.farnagh is offline   Reply With Quote
Old   December 13, 2016, 16:23
Retired Super Moderator
Bruno Santos
Quick answer: I don't have time to try this out myself with OpenFOAM 2.1.1, but a few weeks ago I wrote the instructions for installing OpenFOAM 2.4.0 on Ubuntu 16.10: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.10
Steps #3, #8 and #9 are the ones I expect you will need to use as well for 2.1.1.
k.farnagh likes this.
Old   December 14, 2016, 00:39
Kasra
Thank you Bruno.
You are always helpful to me.
Old   December 14, 2016, 23:11
Vitor Moura
vitormoura is on a distinguished road
Kasra,
I passed 2 entirely days trying to solve OpenFOAM 2.1.1 and Ubuntu 16.04, got alot problems with packages. After those days, I could make OpenFOAM works, but without Paraview.
I can give you 4 tips:
1 - flex --version = 2.5.35
http://repository.timesys.com/builds...-2.5.35.tar.gz
(install instructions inside file)
Reason: OpenFoam v2.1.1 for Ubuntu 16.04
2 - gcc --version = 2.7.x
g++ --version = 2.7.x
http://askubuntu.com/questions/26498...-and-g-version
(download and install instructions inside file)
Reason: http://openfoamwiki.net/index.php/In...tion_.28GCC.29
3 - qt = 4.6.3 (qmake --version)
http://download.qt.io/archive/qt/4.6...c-4.6.3.tar.gz
(install instructions on link below)
Qt version of Paraview 3.8.0 in OpenFOAM 1.7
After all those hacks, OpenFOAM runs perfect on 16.04, but ParaView keeps giving me COPY_FILE erro on VTK and doesn't got make file on the path /OpenFOAM-2.1.1/wmake/rules/linux64Gcc47. (Already downgrade Ubuntu 14.04, don't got make.logs)
4 - If you can, install on Ubuntu 14.04.
Is easy to do it, just do what is saying on for Ubuntu 12.10
https://openfoamwiki.net/index.php/I...M-2.1.1/Ubuntu
only difference is on package I include this:
 sudo apt-get libqt4-opengl-dev freeglut3-dev libqtwebkit-dev  libscotch-dev
I don't know if must add those, but work that way.
wyldckat and k.farnagh like this.
vitormoura is offline   Reply With Quote
Old   December 17, 2016, 16:47
Bruno Santos
Greetings to all!
I've finished writing and testing the complete instructions for building OpenFOAM 2.1.1 in Ubuntu 16.10: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.10
@Kasra: If you are still having trouble building it, hopefully these instructions will make things easier to follow.
@Vitor: Many thanks for sharing your experience!
I'm going to test the instructions I wrote for 16.10 on 16.04 and let you know if they also work for that version. But it should allow building ParaView with Ubuntu's own build of Qt 4.8. I'll edit this post once I'm finished.
edit: I've confirmed that the instructions also work on Ubuntu 16.04
Best regards,
Bruno
k.farnagh, sibo and vitormoura like this.
Old   December 18, 2016, 07:00
Kasra
Thank you Bruno and Vitor for your great guidance.
Old   January 8, 2018, 11:21
Default Bash Ubuntu Installation
firlyrubani is on a distinguished road
Hello, I'm new to OpenFoam, must install the version 2.1.1 cause I want the RisingBubble Tutorial to work out.
I installed this in bash Ubuntu on Windows 10 and got a lots of errors. Does the installation also applicable for bash Ubuntu Windows 10?
Thank you.
firlyrubani is offline   Reply With Quote
Old   January 14, 2018, 11:55
Bruno Santos
Thank you.
Quick answer: I'm not certain if Ubuntu on Windows 10 is using Ubuntu 16.04 or 17.04 or 17.10.
If it is using Ubuntu 16.04, and if you tried following the instructions given here: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.10 - Then please follow the instructions written there that tell you how to package the log files and attach them to your next post.
Old   October 24, 2019, 12:05
Default Issues With installation of OF2.1.1 on Ubuntu 16.04
Nicolas Cerulus
NCerulus is on a distinguished road
Hi I hope you can help me here,
I am trying to install OpenFOAM version 2.1.1 on Ubuntu 16.04 and am following the guide that Bruno posted:
however when i run step #8 i get the following errors:
Cannot open configuration file /home/sgncerul/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/openmpi-1.5.3/share/openmpi/mpicc-wrapper-data.txt
Error parsing data file mpicc: Not found
I've checked and mpicc is present however the platforms folder isn't which from what i've understood gets created when you run Allwmake, so i'm not sure why this is an error before running the Allwmake command. can anyone help?
thanks
Nic
NCerulus is offline   Reply With Quote
[OpenFOAM.org] icoFoam: Command not found in OpenFOAM 3.0.1 installation on Ubuntu 16.10 febriyan91 OpenFOAM Installation 2 July 27, 2020 00:23
Prolem installing OpenFOAM Ver 2.3.0 source in Ubuntu 13.1.0 on VMware zandi OpenFOAM Installation 5 March 31, 2014 03:57
Please help: Installing OpenFOAM-1.5-dev on Ubuntu 9.04 aat OpenFOAM Installation 23 July 21, 2013 06:31
Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 AHutchison OpenFOAM Installation 6 June 4, 2013 12:11
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 04:43
