[OpenFOAM.org] Problem compiling PV4Readers into OpenFOAM 2.4.0
Old   November 14, 2018, 09:05
Default Problem compiling PV4Readers into OpenFOAM 2.4.0
Erik
Spurius is on a distinguished road
Greetings,
I am trying to do some OpenFOAM simulations with the assistance of ParaView. Beforehand: I am new to all of these applications, so excuse me, please, if my terminology (and knowledge) isn't always on point
OpenFOAM (2.4.0) seems to be installed correctly. It has to be mentioned, that I am a new user on this PC (OpenSUSE 42.3; x86_64) on which OpenFOAM and ParaView have already been used.
This is why I only had to build a new user Folder in the OpenFOAM-folder (instead of installing from scratch). What was left was to compile ParaView4 using
$> cd $WM_THIRD_PARTY_DIR
$> ./makeParaView4
which seemed to be successful and to compile the PV4Readers using
$> cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
• $> wmSET
• ./Allwclean
• ./Allwmake
which didn't work. The last command leaves me with
ERROR: ParaView not found in /home/ehrhardt/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc/ParaView-4.1.0
It neither did work with the installation instructions given here (beginning from step 12):
https://openfoamwiki.net/index.php/I...2.4.0/openSUSE
I am aware that many people had a similar Problem before me. I tried, for example, the fixes suggested here:
Paraview not found when installing OpenFoam to Ubuntu 14.04
As an example, I will also add the log that was written using this code (had to add .txt to it to be able to upload it):
sed -i -e 's=CUDA_FOUND=OFF=g' ParaView-4.1.0/Plugins/SciberQuestToolKit/SciberQuest/CMakeLists.txt
./makeParaView4 -qmake $(which qmake-qt4) > log.makePV 2>&1
I hope that was enough information. I was trying not to miss out on anything doing my first post here.
I also opened up a thread on:
https://discourse.paraview.org/t/pv4...o-openfoam/902
Thanks for the help,
Erik
Spurius is offline   Reply With Quote
installation, openfoam 2.4.0, opensuse, paraview 4.1.0
[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview ditmeyer OpenFOAM Installation 3 May 15, 2017 12:04
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
[swak4Foam] problem in compiling groovyBC in OpenFoam 1.71 javad814 OpenFOAM Community Contributions 4 July 31, 2011 04:33
OpenFOAM Install problem masb OpenFOAM 3 May 25, 2009 11:32
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
