[foam-extend.org] upgrade to opensuse leap and now problems to install ofext3.0 |
June 15, 2017, 12:27 |
Tom Dylan
Rep Power: 10 |
Dear foamers,
After having upgraded to openSuse Leap I succeeded installing ofext3.0. But I was no able to compile any solver due to some references of the basic packages (mathematicalConstant) keep unresolved: Code:
Making dependency list for source file boundaries/fixedDisplacementZeroShear/fixedDisplacementZeroShearFvPatchVectorField.C Making dependency list for source file boundaries/standingWaveTheory/standingWaveTheoryFvPatchScalarField.C Making dependency list for source file boundaries/interpolateTimeVaryingTotalTraction/interpolateTimeVaryingTotalTractionFvPatchVectorField.C Making dependency list for source file boundaries/linearVaryingTotalTraction/linearVaryingTotalTractionFvPatchVectorField.C Making dependency list for source file boundaries/zeroTotalTraction/zeroTotalTractionFvPatchVectorField.C Making dependency list for source file boundaries/fixedTotalTraction/fixedTotalTractionFvPatchVectorField.C Making dependency list for source file pDependElastPlastBiotFoam.C g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/meshTools/lnInclude -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/finiteVolume/lnInclude -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/global/constants/mathematical -IincrementTractionDisplacement/lnInclude -IlnInclude -I. -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude -fPIC -c pDependElastPlastBiotFoam.C -o Make/linux64GccDPInt64Opt/pDependElastPlastBiotFoam.o In file included from pDependElastPlastBiotFoam.C:60:0: readSoilProperties.H: In function ‘int main(int, char**)’: readSoilProperties.H:70:39: error: ‘mathematicalConstant’ has not been declared scalar k = ((1 + sin(varPhi/180.0*mathematicalConstant::pi))/(1 - sin(varPhi/180.0*mathematicalConstant::pi))).value(); ^ readSoilProperties.H:70:88: error: ‘mathematicalConstant’ has not been declared scalar k = ((1 + sin(varPhi/180.0*mathematicalConstant::pi))/(1 - sin(varPhi/180.0*mathematicalConstant::pi))).value(); ^ readSoilProperties.H:72:39: error: ‘mathematicalConstant’ has not been declared scalar m = ((1 + sin(varPsi/180.0*mathematicalConstant::pi))/(1 - sin(varPsi/180.0*mathematicalConstant::pi))).value(); ^ readSoilProperties.H:72:88: error: ‘mathematicalConstant’ has not been declared scalar m = ((1 + sin(varPsi/180.0*mathematicalConstant::pi))/(1 - sin(varPsi/180.0*mathematicalConstant::pi))).value(); ^ pDependElastPlastBiotFoam.C:77:9: error: ‘solverPerformance’ is not a member of ‘Foam::lduMatrix’ lduMatrix::solverPerformance solverPerfP; ^ pDependElastPlastBiotFoam.C:77:38: error: expected ‘;’ before ‘solverPerfP’ lduMatrix::solverPerformance solverPerfP; ^ pDependElastPlastBiotFoam.C:78:9: error: ‘solverPerformance’ is not a member of ‘Foam::lduMatrix’ lduMatrix::solverPerformance solverPerfDU; ^ pDependElastPlastBiotFoam.C:78:38: error: expected ‘;’ before ‘solverPerfDU’ lduMatrix::solverPerformance solverPerfDU; ^ pDependElastPlastBiotFoam.C:82:35: error: ‘class Foam::Time’ has no member named ‘controlDic’ word correct=word(runTime.controlDic t().lookup("correctPlasticity")); ^ pDependElastPlastBiotFoam.C:98:6: error: ‘solverPerfP’ was not declared in this scope solverPerfP = pEqn.solve(); ^ pDependElastPlastBiotFoam.C:101:25: error: no match for ‘operator<<’ (operand types are ‘Foam::Ostream’ and ‘void’) Info<< "p_relax = " << p.relax() << " Pa\n"; and some more code I left Code:
EXE_INC = \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/OpenFOAM/global/constants/mathematical \ -IincrementTractionDisplacement/lnInclude EXE_LIBS = \ -lfiniteVolume \ -llduSolvers \ -lmeshTools Any hints warmly appreciated Tom Last edited by tomdylan; June 15, 2017 at 14:11. Reason: title was not conciese enough |
June 18, 2017, 09:11 |
Tom Dylan
Rep Power: 10 |
Somewhat in despair I moved to openFoam ext 4 and made sure that the installation process (under openSuse Leap 42.2) was OK. I successfully managed to compile and to run the plate hole tutorial of the solid mechanics branch.
But when I went to my code, which under oFext3.0 was running fine, an previously unknown error appeared: Code:
pDependElastPlastBiotFoam.C: In function ‘int main(int, char**)’: pDependElastPlastBiotFoam.C:77:9: error: ‘solverPerformance’ is not a member of ‘Foam::lduMatrix’ lduMatrix::solverPerformance solverPerfP; ^ pDependElastPlastBiotFoam.C:77:38: error: expected ‘;’ before ‘solverPerfP’ lduMatrix::solverPerformance solverPerfP; ^ pDependElastPlastBiotFoam.C:78:9: error: ‘solverPerformance’ is not a member of ‘Foam::lduMatrix’ lduMatrix::solverPerformance solverPerfDU; ^ pDependElastPlastBiotFoam.C:78:38: error: expected ‘;’ before ‘solverPerfDU’ lduMatrix::solverPerformance solverPerfDU; ^ pDependElastPlastBiotFoam.C:82:35: error: ‘class Foam::Time’ has no member named ‘controlDic’ word correct=word(runTime.controlDic t().lookup("correctPlasticity")); ^ pDependElastPlastBiotFoam.C:98:6: error: ‘solverPerfP’ was not declared in this scope solverPerfP = pEqn.solve(); ^ pDependElastPlastBiotFoam.C:101:25: error: no match for ‘operator<<’ (operand types are ‘Foam::Ostream’ and ‘void’) Info<< "p_relax = " << p.relax() << " Pa\n"; ^ =lduMatrix=. I have absolutely no idea how to handle/correct this kind of problems... Tom |
June 29, 2017, 16:58 |
Tom Dylan
Rep Power: 10 |
Thank you very much for this hint, Bruno!
Now the solver is compiled without any errors. And that was the reason for confusion: lduMatrix::solverPerformance -> lduSolverPerformance Is there any documentation out there of the syntax changes during the evolution of o30ext - o40ext? Next time I might check the errors myself. Anyway installation of o40x on openSuse Leap 42.2 was successful. Thanks again for your support! Tom |
July 2, 2017, 15:13 |
#5 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
I knew about this bug fix because I had to do it myself last year for the FSI toolkit. You're welcome! |
of3.0x, opensuse leap, unresolved inc |
