[foam-extend.org] Problem with foam-extend-4.0 |
September 12, 2017, 11:11 |
Nicolas Rodio
Hello everyone,
I'm trying to install the openFoam extended-4.0 version, to use the FSIFoam, from this link: https://openfoamwiki.net/index.php/I...om_source_code. Im not good at using Ubuntu, but I'm following the commands to get the source code and then compile the program. So, when I try to run "fe40", it appears: bash: /opt/foam-extend-4.0/bin/foamGetSystemInfo: No such file or directory bash: /opt/foam-extend-4.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-4.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-4.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-4.0/etc/settings.sh: No such file or directory bash: /opt/foam-extend-4.0/etc/aliases.sh: No such file or directory bash: /opt/foam-extend-4.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-4.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-4.0/bin/foamCleanPath: No such file or directory What I should do to get the OpenFoam extended?? Last edited by Nicolas Rodio; September 13, 2017 at 08:41. |
December 31, 2017, 11:36 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I'm really late on this, but the solution is that you need to use aliases to make it easier to use each OpenFOAM/foam-extend version independently. Details are available at section 2.2 "Using aliases to help manage multiple OpenFOAM versions", here: https://openfoamwiki.net/index.php/I...nFOAM_versions
December 6, 2018, 20:03 |
Xuxiang Cao
Rep Power: 9 |
i had this problem too;
maybe you can reboost your computer. |
July 29, 2020, 15:06 |
CODE for non-isothermal viscoelastic models
idrees khan
Rep Power: 6 |
Hello everyone.
i'm going to rewiew a paper ( link for the paper doi:10.1016/j.cnsns.2010.07.006 )in foam-extend-4.0 version .kindly if any has code share with me or guide me how to handle.I have some questions, 1.which form of governing equation's(momentum, Heat ,relaxation time and viscosity etc ) should I use dimension form or non dimensional form,if I'm using dimension there are some parameters whose values are not,given. 2.In the constitutive equation(Oldroyd-B model) there is log of temperature as well.how I would write it in equation. 3.how I will decide to write fvc(explicit treatment) and fvm(implicite treatment) sp and sup with different terms in equation,while writing in main source code file. 4.here the Reynolds no(Re)and Deborah no(De)is small is there still need of using Devss(which is normally used for incorporating high Re,De no's) according to my knowledge) etc forms for governing equation's(momentum,Heat , relaxation time and viscosity etc ), Kindly help me I shell be very thankful, Last edited by idrees khan; August 3, 2020 at 04:05. |
error, extended, openfoam, problem |
Problem using turbulent modelling with rhoCentralFoam in foam extend 4.0 | quarkz | OpenFOAM Running, Solving & CFD | 1 | May 8, 2023 13:27 |
[foam-extend.org] How to install foam-extend 4.0 in UBUNTU 18.04 | silvino | OpenFOAM Installation | 19 | June 21, 2022 15:57 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
probe Locations error in the dynamicMesh foam extend 4.0 | vahidreza lotfi | OpenFOAM Post-Processing | 2 | August 22, 2018 10:30 |
Moving mesh (dynamic motion) with immersed boundary - foam extend 4.0 | abavo | OpenFOAM Running, Solving & CFD | 0 | August 2, 2018 09:25 |
