[foam-extend.org] Foam-extend-4.0 compilation stuck at ThirdPary Stage 5 |
April 15, 2020, 11:50 |
Stefania Zunino
I am trying to install foam-extend-4.0 on Ubuntu 18.04.4 LTS. I have followed these guidelines https://openfoamwiki.net/index.php/I...om_source_code and https://openfoamwiki.net/index.php/I...end-4.0/Ubuntu. Unfortunately, when compiling I did not save the log file, but attached is a screenshot of the error message I am getting. I seems the compilation is stuck at Stage 5 - when installing swak4Foam? - of the ThirdParty installation process. I have tried to run icoFoam on a tutorial and it works, so I am not sure of what was correctly installed and what was not. The same problem was reported in a previous thread, but was not solved: Problems on installing Foam-extend 4.0/ swak4Foam on ubuntu18.0.4 I would like to avoid problems in the future and know everything was at least installed correctly in the first place. I am new to OpenFoam and Ubuntu, so any help would be appreciated! Last edited by stitch; April 17, 2020 at 05:31. |
foam-extend 4.0, swak4foam error, third party |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[foam-extend.org] Fluid Structure Interaction Toolkit on foam extend 4.0 | Bazinga | OpenFOAM Installation | 1 | August 17, 2020 22:51 |
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 5 | June 22, 2019 02:56 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
