[foam-extend.org] Problems installing the FSI-toolkit on foam-extend-4.0
Old   June 20, 2021, 17:50
Post Problems installing the FSI-toolkit on foam-extend-4.0
Elstro is on a distinguished road
I tried to install the FSI-toolkit on foam-extend-4.0 on Ubuntu 18.04. LTS. I am working with the Oracle Virtual Box.
After successful installing of foam-extend-4.0 (I tried the blockMesh-command and it was working) I installed the FSI-toolkit with the following link:
1) https://www.researchgate.net/publica...rse_Notes_2019 (page 33)
I did all steps for installing the toolkit and started to run the tutorial 'beamInCrossFlow'. After a few seconds the simulation stops with the following error message:
./Allrun
Running blockMesh on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid
Running setSet on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid
Running setsToZones on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file setInletVelocity.C
SOURCE=setInletVelocity.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I../../../../src/fluidSolidInteraction/lnInclude     -I/home/pit1/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/pit1/foam/foam-extend-4.0/src/finiteArea/lnInclude     -I/home/pit1/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/pit1/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/pit1/foam/foam-extend-4.0/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/pit1/foam/foam-extend-4.0/src/foam/lnInclude -I/home/pit1/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setInletVelocity.o
/usr/bin/ld: cannot find -lfluidSolidInteraction
collect2: error: ld returned 1 exit status
/home/pit1/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/pit1/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsetInletVelocity.so' failed
make: *** [/home/pit1/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsetInletVelocity.so] Error 1
Running fsiFoam on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid
I don't know how to solve the problem. I still reinstalled the foam-extend version and the toolkit on a new virtual machine and it is still not working...
Can you help me? Any help is appreciated!
Elstro is offline   Reply With Quote
[foam-extend.org] Problems on installing Foam-extend 4.0/ swak4Foam on ubuntu18.0.4 XJ_Wang OpenFOAM Installation 22 December 19, 2021 07:55
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
Using createPatch and cyclicAMI in FOAM Extend 4.0 mekim OpenFOAM Pre-Processing 1 June 20, 2020 05:19
[FSI] Installing FSI toolkit in foam-extend 4.0 treem22 OpenFOAM CC Toolkits for Fluid-Structure Interaction 5 August 8, 2019 06:06
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
