[foam-extend.org] Can I install foam-extend-4.1 together with openfoam v8 on my machine? |
February 26, 2022, 15:03 |
Mert Tmr
Rep Power: 4 |
I do have openfoam v8 running on my machine. But I also like to use the Immersed Boundary Method's implementation on foam-extend-4.1. Can I have both openfoam v8 and foam-extend-4.1 installed on the same machine? Best regards, - Mert |
February 27, 2022, 02:23 |
Ashutosh
Rep Power: 4 |
Yes, Just use alias for switching between versions.
February 27, 2022, 12:36 |
Mert Tmr
Rep Power: 4 |
Dear Ashutosh,
Thanks to your hint and the following link, I could get both of them working on my machine. https://openfoamwiki.net/index.php/I...nFOAM_versions Cheers |
extend, installation, openfoam |
Difference between OpenFOAM and FOAM extend | ce73stargazer | OpenFOAM | 9 | November 10, 2019 10:00 |
[OpenFOAM.org] Install OpenFOAM without admin right | OpenFoamlove | OpenFOAM Installation | 1 | December 31, 2017 11:45 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[Other] cgnsToFoam problems with "QUAD_4" cells | lentschi | OpenFOAM Meshing & Mesh Conversion | 1 | March 9, 2011 04:49 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
