[OpenFOAM.com] How to install dsmcfoam+ having OpenFoam 8 on Ubuntu 20.04 LTS |
April 19, 2022, 02:33 |
Bya
Hello!
I am struggling trying to install dsmcfoam+. I have succeeded in installing OpenFoam 8 on Ubuntu 20.04 LTS. Then, I found this website which explains how to install dsmcfoam+ with OpenFoam 240: https://github.com/Eliasfarah0/dsmcF...on-Crew-Module Is there any way in which dsmcfoam+ can work with OpenFoam 8? I couldn't find anything online |
July 19, 2022, 10:46 |
Alexander Cushen
Rep Power: 3 |
I have just been working through the same issue! I would recommend following the instructions from https://hystrath.github.io/installation/
It's not foolproof, but if you first install openfoam-v1706 (which is the most recent version dsmcFoam+ is compatible with) and follow the instructions on that site, you should be able to get things running. Installing openfoam-v1706 is a bit more manual than other versions, so I would recommend reading through the installing instructions here as a guide. Let me know if you run into more problems! I will help however I can, I know it can be a frustrating installation process. |
May 12, 2024, 09:55 |
Shahriar
Rep Power: 2 |
Hello AlexanderCushen
the link you provided does not work. Can you please give a valid link? I am also trying to install dsmcfoam/dsmcfoam+.. but neither of them working. Currently openfoam-v2312 is installed in my pc. pls help |
[OpenFOAM.com] Installing OpenFOAM 2.4.0 on Ubuntu 20.04 for Windows | RKyle | OpenFOAM Installation | 5 | January 25, 2022 10:45 |
[OpenFOAM.com] OpenFoam v1706 on ubuntu 20.04 and lubuntu 16.04 | tanmay singhal | OpenFOAM Installation | 0 | September 1, 2020 09:11 |
[OpenFOAM.com] OpenFOAM v1.7.1 on Ubuntu 14.04 LTS | reza_65 | OpenFOAM Installation | 3 | August 28, 2017 14:29 |
[OpenFOAM.org] OpenFOAM 2.40 installation on Ubuntu 12.04 LTS | eddykendo | OpenFOAM Installation | 1 | July 18, 2015 17:38 |
OpenFOAM v1.7.1 on Ubuntu 12.04 LTS | makaveli_lcf | OpenFOAM Installation | 8 | October 15, 2012 16:50 |
