[OpenFOAM.com] ThirdParty-v2006 Error building gcc-4.8.5 with ./makeGcc Centos8 |
May 10, 2022, 10:44 |
Huw
I am trying to install Openfoam-v2006 on my local machine which is running Centos8. I have been following the linked instructions (https://sourceexample.com/en/6fd29c0ca6c4680b69dd/) but when it comes to build GCC with the ./makeGcc command I get the following error: make: *** [Makefile:886: all] Error 2 Error building: gcc-4.8.5 After much troubleshooting I haven't been able to find an explanation of what Error 2 refers to, or any others with the same issue. If anyone has experience with the same issue or could offer some guidance that would be much appreciated. Thanks |
May 10, 2022, 11:09 |
#2 | |
Mark Olesen
Rep Power: 40 |
If you have centos-8 I really don't know why you would want to bother building a much, much older compiler from scratch. Simply doesn't make sense to me. If you want to use older/new compilers, by far the easiest is to install them from your system. If you need to reference different system compilers, use the WM_COMPILE_CONTROL (see etc/bashrc for comments) to pick the version. My current compilation setup: Code:
# etc/prefs.sh export WM_COMPILER_TYPE=system export WM_COMPILER=Clang140 export WM_COMPILE_CONTROL="version=14.0 +lld" |
May 10, 2022, 11:30 |
Huw
Thank you for your reply. I am attempting to use the third party packages from ThirdParty-v2006 which as far as I'm aware requires WM_COMPILER_TYPE=ThirdParty in etc/bashrc. Is it possible to build the third party packages (e.g scotch) using a system-installed compiler? If so, how would I go about doing so.
May 11, 2022, 05:56 |
#4 | |
Mark Olesen
Rep Power: 40 |
Using the system compiler for other ThirdParty components is completely standard. The main (only?) reason for making your own ThirdParty gcc etc would be if you have a really, really old operating system with an old compiler (eg, gcc-4.4) that does not support c++11. The only other reason (what I have) is on new system but need to check if the OpenFOAM code is still acceptable for old compilers. |
November 4, 2023, 07:41 |
Problem with too high gcc version
#5 | |
Yanjun Tong
Rep Power: 5 |
When you using this compiler to compile OpenFOAM-2.3.x, got error: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister] 335 | register label i = min(this->size_, newSize); Will this effect the compile process? |
[foam-extend.org] foam-extend-4.1 cannot compile on Centos8 | Ya_Squall2010 | OpenFOAM Installation | 2 | July 22, 2020 02:03 |
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam | powerline332 | OpenFOAM Installation | 3 | May 24, 2018 21:16 |
OpenFOAM 1.6 ext | fportela | OpenFOAM Installation | 11 | December 26, 2013 18:55 |
Thirdparty mesquite-2.1.2 compile fix for newer gcc | kmooney | OpenFOAM Bugs | 3 | May 10, 2012 09:27 |
