Problem in Paraview While installing OpenFOAM 15 in Suse 103 |
February 20, 2009, 05:48 |
Hello All,
I am trying to i
Altran India
Hello All,
I am trying to install OpenFOAM 1.5 on Suse Linux Enterprise server 10.3. I am new to Linux world so following the readme word by word...everything seems to work fine uptill the point where we need to compile the Paraview3.3-cvs. The ./Allwmake command fails with the following error: Linking CXX shared library /home/skumar/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libPV3FoamReader_SM.so /usr/bin/ld: cannot find -lvtkPVFiltersCS make[1]: Leaving directory `/home/skumar/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing' make: *** [postProcessing] Error 2 make: Target `application' not remade because of errors. + '[' '' = doc ']' my foamInstallationTest script is ruuning fine. Any help will be appreciated!!! Thanks in Advance Rohit Sah |
February 20, 2009, 09:20 |
hello,
I guess your system
Rishi .
hello,
I guess your system is Suse 10 Enterprise editiond (SLED 10) or OpenSuSE 10.3 Suse has some missing packages esp. mpfr and gmp. download them and it might work. check the details on my previous post: http://www.cfd-online.com/OpenFOAM_D...tml?1232409169 Or just use search function and you might find answers, since this has been discussed several times. http://www.cfd-online.com/cgi-bin/Op...cus/search.cgi My experience: It was relatively easier to install paraFoam/ParaView on OpenSuSE 10.3 than SLED 10. I use Paraview 3.4.0 precompiled version from Paraview site instead of paraFoam. One needs to run foamToVTK command to get the data in VTK paraview format & then view in paraview. good luck -Rishi |
Pls help last problem to be solved for installing OPENfoam | daydayuper | OpenFOAM Installation | 5 | November 9, 2008 04:59 |
Installing OpenFOAM without Paraview | quartzian | OpenFOAM Installation | 0 | September 8, 2008 09:29 |
Problem installing OpenFOAM 141 | sachin | OpenFOAM Installation | 2 | February 22, 2008 10:20 |
[OpenFOAM] ParaView problem under SUSE 10_64 | hsieh | ParaView | 3 | March 27, 2006 01:12 |
Installing OpenFOAM on SuSE Linux 91 | Lars Edvardsen (Edvardsen) | OpenFOAM Installation | 2 | January 10, 2005 02:26 |
