OpenFoam 1.7 Installation
Old   June 30, 2010, 08:42
Default OpenFoam 1.7 Installation
Robyn
robyn is on a distinguished road
Hello!
I'm currently trying to reinstall OpenFoam using version 1.7.0 on OpenSuse 11.2.
There were no problems with version 1.6 until I close the terminal window. The pathways to use for example blockMesh are then no longer there. So I hope that version 1.7.0 will no longer have this problem. However, I'm now having problems sourcing bashrc.
After unpacking the files I will go into the $HOME/.bashrc by typing:
vi $HOME/.bashrc
I added the following line:
#export PILOTPORT=/dev/pilot
#export PILOTRATE=115200
.$HOME/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc <------
type esc, then :wq to write and quit the editor.
From there the installation guide asks you to type
.$HOME/.bashrc
into the terminal window (within /etc directory). However, when I do this it states the directory does not exist.
Any ideas would be appreciated!
Cheers
Robyn
robyn is offline   Reply With Quote
Old   June 30, 2010, 09:18
Retired Super Moderator
Bruno Santos
Greetings Robyn and welcome to the forum!
OK, a little explanation: the dot, in this case, at the beginning of the command line does the same thing as the "source" command. When the dot at the beginning of a command line is the command itself, then a space must be put in between the dot and the rest of the command line
So, what you should have in your $HOME/.bashrc file (in this case, the dot is part of the file name and that this file should be hidden) is this:
. $HOME/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc
Notice the space between the dot and $HOME! This way the file is properly sourced.
Now, you can either start a new terminal or run this command (anywhere, doesn't need to be in the /etc folder):
. $HOME/.bashrc
Again, notice the space between the dot and $HOME!
Now, you might ask "what does it mean to source a file?" Well, it means that the file is not to be just executed as a script, but it should be executed as if it were a function that updates your current shell environment! And that's how the OpenFOAM environment gets set-up and ready to go
Best regards,
Bruno
Old   June 30, 2010, 09:38
Robyn
Hello Bruno!
Thanks for the words of wisdom and advice. After following you explanation I now find an error for the foamInstallationTest as follows
Executing /home/robyn/OpenFOAM/OpenFOAM-1.7.0/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: linux-4ifd
OS: Linux version 2.6.31.5-0.1-desktop
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/robyn/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/robyn/OpenFOAM/robyn-1.7.0 no no
$WM_THIRD_PARTY_DIR /home/robyn/OpenFOAM/ThirdParty-1.7.0 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/robyn/OpenFOAM/OpenFOAM-1.7.0 yes yes yes
$FOAM_APPBIN ...1.7.0/applications/bin/linuxGccDPOpt no yes
$FOAM_SITE_APPBIN ...penFOAM/site/1.7.0/bin/linuxGccDPOpt no no
$FOAM_USER_APPBIN ...1.7.0/applications/bin/linuxGccDPOpt no no
$WM_DIR .../robyn/OpenFOAM/OpenFOAM-1.7.0/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt no yes
$FOAM_SITE_LIBBIN ...penFOAM/site/1.7.0/lib/linuxGccDPOpt no no
$FOAM_USER_LIBBIN ...enFOAM/robyn-1.7.0/lib/linuxGccDPOpt no no
$MPI_ARCH_PATH ...7.0/platforms/linuxGcc/openmpi-1.4.1 no yes
Third party software
Software Version Location
/home/robyn/OpenFOAM/OpenFOAM-1.7.0/bin/foamInstallationTest: line 258: [: -lt: unary operator expected
gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.21 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/robyn/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linuxGccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
*** The foam installation contains 1 critical error(s)
*** Review the output for warning messages and consult
*** the installation guide for trouble shooting.
Old   June 30, 2010, 09:45
Bruno Santos
Hi Robyn,
Well, OpenFOAM 1.7 only has a prebuilt version for Ubuntu. So I'll have to refer you now to this thread: http://www.cfd-online.com/Forums/ope...-2-11-3-a.html
It has links to instructions on how to build OpenFOAM 1.7 in OpenSUSE 11.2 and 11.3
Best regards,
Bruno
Old   June 30, 2010, 09:54
Robyn
Hello Bruno,
Thanks for the link. I think I might be missing a line in my $HOME/.bashrc file as before there was a test true... at the end of the file I forgot that I deleted. Could this potentially be the problem as the wmake step is not found.
Regards,
Robyn
Old   June 30, 2010, 10:15
Robyn
Thanks Bruno, I will work on it and see where it goes.
Do you know where I could still retrieve a copy of OF 1.6 ? As I was beginning to build my own cases and would not like to be stuck in this position for long.
Regards,
Robyn
Old   June 30, 2010, 11:20
Bruno Santos
Hi Robyn,
OpenCFD's repository for OpenFOAM files is this: http://sourceforge.net/projects/foam/files/
You can get from there all OpenFOAM's since 1.1
Best regards,
Bruno
Installation how-to's - OpenFOAM 1.7 - openSUSE 11.2 and 11.3 alberto OpenFOAM Installation 24 August 4, 2010 00:48
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
