[Other] openFoam 2.3.x for windows from cfdsupport.com
Like Tree2Likes
Old   July 18, 2014, 04:43
Default openFoam 2.3.x for windows from cfdsupport.com
Paritosh Vasava
vasava will become famous soon enough
Now you can download openFoam 2.3.x for windows from the give link (http://www.cfdsupport.com/openfoam-for-windows.html). I have downloaded and checking it right now. There is ready-to-install .exe files. No-cross compiling is needed and it looks quite promising.
There is no read-me file so I am not sure about the sequence of installation. If would be nice to hear what everyone else has to say.
vasava is offline   Reply With Quote
Old   July 18, 2014, 04:48
Paritosh Vasava
My bad. There is a link about installation instructions (http://www.cfdsupport.com/install-op...r-windows.html).
Old   July 23, 2014, 10:40
Default looks nice
OH il seok
oilsok is on a distinguished road
I tested this complied OpenFoam for windows.
It works well
but I wonder how to compile OpenFOAM on cygwin...I need to combine some solver
oilsok is offline   Reply With Quote
Old   July 24, 2014, 02:34
Paritosh Vasava
I am not sure about that you can ask the support at cfdsupport.
Old   July 24, 2014, 10:07
Fabio is on a distinguished road
Hi all, i'm stuck at point 6 of step 3, i don't have any
C:\cygwin64\opt\OpenFOAM\ folder, shuold i create it?
I haven't restrted the system after
run OpenFOAM-2.3.x-reg.bat
shoul be that the problem?
Fabio is offline   Reply With Quote
Old   August 26, 2014, 09:58
Question OpenFoam 2.3.x for Windows installation trouble
Theodor C
Theodor is on a distinguished road
Hi all!
I'm newbie to OpenFOAM. I tried to install it using cfdsupport.com instructions. But when I try to run example icoFoam I recieve this error:
-bash: blockmesh: command not found
What is the reason?
Thanks in advance,
Theodor C
Theodor is offline   Reply With Quote
Old   October 1, 2014, 10:07
Xiaopeng Wang
Wang@nitech is on a distinguished road
Hi Fabio,
Yes, you should create the directory yourself.
Wang@NIT
Wang@nitech is offline   Reply With Quote
Old   October 1, 2014, 10:10
Xiaopeng Wang
Originally Posted by Theodor View Post
Hi all!
What is the reason?
Thanks in advance,
Theodor C
Hi Theodor,
You should also install MS-MPI contained in the installation directory.
The file name is MSMPISetup.
Wang@NIT
Old   October 1, 2014, 10:25
Oh thank you!
This installation process is valid also for other linux only packages lika Code Aster?
Old   October 1, 2014, 20:58
Xiaopeng Wang
Oh thank you!
I'm sorry. I am new to OpenFOAM, I have no idea about that.
Old   October 5, 2014, 04:53
Simas
zombiaska is on a distinguished road
As I undertand this installation is only for win 64
zombiaska is offline   Reply With Quote
Old   October 6, 2014, 01:37
Paritosh Vasava
Oh thank you!
This process is for installing openFoam on windows. You can look at openFoam website for instructions for installation on linux. Perhaps this link could help.
Old   October 6, 2014, 04:30
Nikolay Nosorev
Logrus is on a distinguished road
After installation some days ago it worked,
but recently it "crashed".Inputing commands has no respond.I checked system variables (PATH), but openfoam commands ignored(.Bash is not write that commands not found,but they are not works anymore.
Logrus is offline   Reply With Quote
Old   October 12, 2014, 00:06
Xinping Zhou
Markzhou is on a distinguished road
Dear Theodor,
I have the same problem as yours. How did you solve this problem?
Thank you.
Mark
Hi all!
What is the reason?
Thanks in advance,
Theodor C
Dear Wang,
I have the same problem as Theodor's, though I installed MS-MPI contained in the installation directory. How should I DO in order to solve this problem?
Thank you.
Mark
Originally Posted by Wang@nitech View Post
Hi Theodor,
Wang@NIT
Last edited by wyldckat; October 12, 2014 at 02:22. Reason: merged posts, which were posted 2 minutes apart
Markzhou is offline   Reply With Quote
Old   October 29, 2014, 06:20
deepinheart is on a distinguished road
It works well
Hi Oilsok,
I'm wondering the same and have asked cfd support but no reply jet. Have you got any info?
Thanks!
deepinheart is offline   Reply With Quote
Old   October 29, 2014, 08:28
Paritosh Vasava
@ Logrus and @ deepinheart: Did you update your windows installation recently? May be some one more expert can comment if updating windows has something to do with this.
Also have you tried re-installing openFoam from scratch?
Old   November 6, 2014, 08:25
Default can't find blockMesh
  #17
Isha Schoots
schootsi is on a distinguished road
I installed OpenFOAM on windows using cygwin64. I'm trying to do the first tutorial, but when I run blockMesh it says:
admin@-PC /opt/OpenFOAM/OpenFOAM-2.3.x/tutorials/incompressible/icoFoam/cavity
$ blockMesh
/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/blockMesh.exe: error while loading shared libraries: ?: cannot open shared object file: No such file or directory
Whereas the file is in that location, as far as I can tell. In fact it can find the directory, and in Windows I can see the file is there.
$ cd C:/cygwin64/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin
admin@-PC /opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin
$ blockMesh
It seems to me this error is different from the 'command not found' blockmesh error? Does anyone have a clue what I might be doing wrong?
schootsi is offline   Reply With Quote
Old   November 12, 2014, 12:43
Default Solution for "error while loading shared libraries: ?"
  #18
Andras Horvath
andras is on a distinguished road
1) Start "OpenFOAM-2.3.x-reg.bat" with admin rights (right click -> Run as Administrator). The install instructions from cfdsupport.com are missing this crucial step. Admin rights are needed for the registry key "HKLM\SYSTEM\CurrentControlSet\Control\SessionMana ger\kernel".
2) Don't source $WM_PROJECT_DIR/etc/bashrc in bash like you are used to for standard installations of OpenFOAM unter *NIX systems.
3) Simply run the solver (paths are searched automatically).
Cheers
Andras
andras is offline   Reply With Quote
Old   November 12, 2014, 12:52
Isha Schoots
So I reinstalled the whole thing again and blockmesh is working now. I think I may have installed the components in the wrong order or skipped ms-mpi before
Both blockMesh and icoFoam work now, and paraview works as well (also from cygwin), however paraFoam returns the error: -bash: paraFoam: command not found. I've seen this error on this forum on other OS's, but I couldn't find anything for the Windows situation.
Has anyone had this problem? Any thoughts on how to solve it?
Thanks in advance!
Old   November 12, 2014, 13:38
Default Work-around for parafoam:
  #20
Andras Horvath
In your case directory:
$ touch .foam
$ paraview .foam
Cheers
Andras
schootsi likes this.
openfoam, windows
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
[OpenFOAM.org] OpenFOAM 2.3.x for Mac at GitHub ajmas OpenFOAM Installation 2 April 20, 2015 16:23
[OpenFOAM.org] Installing OpenFOAM 2.3.x on Ubuntu 14.04 samiam1000 OpenFOAM Installation 4 January 26, 2015 02:44
