environment variables- CAE Linux
Old   April 13, 2012, 17:42
Default environment variables- CAE Linux
kal
neha
kal is on a distinguished road
For OpenFOAM on CAE Linux platform, how do I configure the environment?
e.g. adding the following line to $HOME/.bashrc does not work
. $HOME/OpenFOAM/OpenFOAM-2.0.1/etc/bashrc
I tried changing the path to opt/openfoam201/etc/bashrc,
but then sourcing by
. $HOME/.bashrc
does not do anything.
I would really appreciate any help on this.
kal is offline   Reply With Quote
Old   April 14, 2012, 06:46
Retired Super Moderator
Bruno Santos
Greetings kal and welcome to the forum!
Edit your "$HOME/.bashrc" file and add this line (or modify the line you added to this):
. /opt/openfoam201/etc/bashrc
edit: I forgot to mention that you can also execute this line directly on the terminal window.
Good luck!
Bruno
Old   April 15, 2012, 11:05
kal
neha
Thanks for your reply! I tried to put the line you suggested in the bashrc file, save, and execute . $HOME/.bashrc.
However, when I run foamInstallationTest, I still get the error that the OpenFOAM environment is not configured. This is how it looks like:
neha@neha:~$ gedit ~/.bashrc
neha@neha:~$ . $HOME/.bashrc
neha@neha:~$ foamInstallationTest
Executing /opt/openfoam201/bin/foamInstallationTest:
Checking basic setup...
FATAL ERROR: OpenFOAM environment not configured.
Please refer to the installation section of the README file:
<OpenFOAM installation dir>/OpenFOAM-2.0.1/README
to source the OpenFOAM environment.
Please let me know if you can figure out what the error is from this.
Thanks again!
Old   April 15, 2012, 16:52
Bruno Santos
Hi kal,
The script foamInstallationTest was designed for source builds only and will not work for the Deb and RPM packages. In CAE Linux, it used a Deb package, so that is why it doesn't work.
The standard test is to run:
icoFoam -help
If it shows the help instructions for icoFoam, then it's working. You can see this information here: http://www.openfoam.org/download/ubuntu.php - section "User Configuration".
Best regards,
Bruno
Old   April 16, 2012, 11:06
kal
neha
OK.. Thanks for your help Bruno!
'Set Environment Variables' for Fluent 12 DarrenC Fluent UDF and Scheme Programming 2 May 25, 2011 15:51
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Gentoo Environment Variables scottneh OpenFOAM Installation 1 September 20, 2009 12:21
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
