Building OpenFOAM 2.0.1 on SLES 10 SP1 x86_64
Like Tree2Likes
  • 1 Post By wyldckat
Old   February 8, 2012, 05:39
Default Building OpenFOAM 2.0.1 on SLES 10 SP1 x86_64
Hrushikesh Khadamkar
Hrushi is on a distinguished road
I am trying to bulid openfoam 2.0.1 on SLES 10 SP1 x86_64 on the lines described in floowing link by Bruno Santos.
http://www.cfd-online.com/Forums/blo...untu-8-04.html
There was an error in buliding cmake-2.8.3. See mkcmake.log file.
However, I went ahead and followed next steps till end as described in above link. I have attached the output of ./Allwmake in two files due to size constraints on file upload.
There is problem with paraView also. See mkPV.log file
Can anybody help me in this?
Thanks
Hrushikesh
Hrushi is offline   Reply With Quote
Old   February 8, 2012, 06:24
Retired Super Moderator
Bruno Santos
Hi Hrushikesh,
I've searched a bit and found this - http://gcc.gnu.org/bugzilla/show_bug.cgi?id=43882#c5:
I used -R/path/to/4.5.0/libstdc++.so to fix this library path. But it turns out that -L/path/to/4.5.0/libstdc++.so is also required in addition to this, otherwise the default libstdc++.so is looked up by linker.
This would solve the problem with building CMake. But I'll only be able to check this for myself in about 10h from now
In the mean time, you can check another blog post of mine: Using the official pre-built ParaView 3.10.1 version with OpenFOAM - it's a bit outdated, but a bit of tweaking should fix the differences.
Best regards,
Bruno
Old   February 8, 2012, 16:42
Bruno Santos
Hi Hrushikesh,
I've managed to figure the problem! And the issue was already fixed back in September 2011: https://github.com/OpenFOAM/ThirdPar...c22adcab144d5e - I simply didn't pick up on it sooner
Run in the ThirdParty folder the following commands:
rm makeCmake
 wget "https://raw.github.com/OpenFOAM/ThirdParty-2.0.x/master/makeCmake"
chmod +x makeCmake
Then you can properly build CMake and ParaView!
Good luck!
Bruno
Old   February 9, 2012, 08:18
Hi Bruno,
Thanks a lot. I will try your suggestion and will update you soon on the same.
Again Thanks.
Hrushikesh
Old   February 10, 2012, 07:46
Default Building OpenFOAM 2.0.1 on old Linux OSes SUSE 10 SP1 x86_64
Hi Bruno,
Yes, that did the trick.
[QUOTE=wyldckat;343460]
rm makeCmake
chmod +x makeCmake
Now both OpenFOAM-2.0.1 and paraView 3.10.1 are succesfully built.
But then I ran into another problem. I can't run my solvers in parallel. See the error file parallel-error.tar.gz
code: mpirun -np 8 'foamExec' interFoam -parallel
However I can run solvers using single processor.
Can you help me in this?
Thanks
Hrushikesh
Old   February 10, 2012, 15:28
Bruno Santos
Hi Hrushikesh,
Ouch, that's a crazy crash...
OK, it looks like it is having problems with the Infiniband system... does your system have Infiniband?
Either way, there are at least three options:
  1. Re-compile Open-MPI without "openib".
  2. Use your system's Open-MPI or any other MPI that it has by default (MPICH, Intel MPI, etc).
  3. Try running mpirun with the option for disabling certain NICs:
    Originally Posted by pkr View Post
    The problem is solved if the following command is used:
    mpirun --mca btl_tcp_if_exclude lo,virbr0 -hostfile machines -np 2 /home/rphull/OpenFOAM/OpenFOAM-1.6/bin/foamExec interFoam -parallel
    The above command will restrict MPI to use certain networks (lo, vibro in this case).
Best regards,
Bruno
Old   February 11, 2012, 10:03
[QUOTE=wyldckat;343854]Hi Hrushikesh,
    I don't know how to do this?
    Can you give some tips on this?
I tried this. But It still gave me same error as previously.
Thanks
Hrushikesh
Old   February 11, 2012, 11:36
Bruno Santos
Hi Hrushikesh,
Edit the file "OpenFOAM-2.0.1/etc/config/settings.sh" and you'll see several MPIs available after the following zone:
# Communications library
unset MPI_ARCH_PATH MPI_HOME FOAM_MPI_LIBBIN
case "$WM_MPLIB" in
OPENMPI)
After you check which MPI you have and/or adapt the one you need, edit the file "$HOME/.bashrc" and change the line:
alias of201='source  $HOME/OpenFOAM/OpenFOAM-2.0.1/etc/bashrc foamCompiler=ThirdParty  WM_COMPILER=Gcc45 WM_NCOMPPROCS=4 WM_MPLIB=MPICH'
Where MPICH is the MPI you want.Then start a new terminal or run "source $HOME/.bashrc"; then run "of201".
Best regards,
Bruno
Old   February 18, 2012, 13:27
Hi Bruno,
I have tried with suggestions made by you. But still I can not fire my runs in parallel using OpenFoam 2.0.1 on the cluster.
What can be the reason for this? Shall I need to recompile openmpi? If yes , how to do that?
Thanks
Hrushikesh
Old   February 18, 2012, 16:24
Bruno Santos
Hi Hrushikesh,
I can't figure it out with so little information...
Anyway, to rebuild your custom Open-MPI, you can remove it by running:
echo $MPI_ARCH_PATH
ls -l $MPI_ARCH_PATH
rm -r $MPI_ARCH_PATH
The first two lines helps you check if you are really erasing the right folder. The third one erases the Open-MPI you built.
Then it's just a matter of running Allwmake once again.
The one thing I don't understand is why the libraries for Infiniband were built!? Did you modify anything in the "ThirdParty-2.1.x/Allwmake" script?
Best regards,
Bruno
Old   February 18, 2012, 17:53
Hi Bruno,
I tried with all available mpi. Then modified .bshrc accordingly. The machine is giving me error (See mpi-error file).[had forgotten to attach error file in previous post]
Libraries for Infiniband were already built before installing OpenFoam. I have not modified anything in the "ThirdParty-2.1.x/Allwmake" script.
So looking at the error, shall I need to rebuild the MPI and again do Allwmake?
Thanks
Hrushikesh
File Type: txt mpi-error.txt (761 Bytes, 7 views)
Old   February 19, 2012, 06:39
Bruno Santos
Hi Hrushikesh,
Mmm... I noticed just now that you are running the command in a very bad way. Do not run it like this:
Run it like this:
mpirun -np 8 `which foamExec` interFoam -parallel
There is a simpler way of doing this:
foamJob -s -p interFoam
It (usually) detects the necessary number of cores and the "-p" option launches things in parallel.
If this still doesn't work, then you'll have to do some more tests before trying the solver itself, since this might be a problem with configuring the MPI to work with OpenFOAM and your machine. Here are some old instructions on how to test things:
On how to test if MPI is working: post #4 of "openfoam 1.6 on debian etch", and/or post #19 of "OpenFOAM updates" - Note: As of OpenFOAM 2.0.0, the application "parallelTest" is now called "Test-parallel".
Best regards,
Bruno
Old   February 20, 2012, 01:47
Hi Bruno,
This also gives the same error as posted in previous posts.
This gives the following output. (See file foamJob-master).
I have done the testing as described by you in above posts. The application did got compiled. But foamJob -p -s Test-parallel throws error.The output is in file test-parallel.
Thanks
Hrushikesh
File Type: zip foamJob-master.zip (433 Bytes, 2 views)
File Type: zip test-parallel.zip (770 Bytes, 3 views)
Old   February 20, 2012, 04:33
Bruno Santos
Hi Hrushikesh,
You've got a big problem there, mainly because you're not taking into account several important details:
  1. You should first do the tests on the machine where you built OpenFOAM. This will confirm to you if things are working or not.
  2. You are trying to launch OpenFOAM applications on a cluster where OpenFOAM is not properly installed! When launching OpenFOAM applications, it expects that all machines have the same OpenFOAM installation path.
  3. The case folder must be accessible on all machines, or at least properly indicated on "system/decomposeParDict". This includes the need for a writable processor folder from each machine!
Unfortunately I don't have time right now to go into more details, so I'll have to refer you to my Notes about running OpenFOAM in parallel
Best regards,
Bruno
Old   February 20, 2012, 10:18
Hi Bruno,
Originally Posted by wyldckat View Post
Hi Hrushikesh,
Best regards,
Bruno
1.> I did the test on the machine on which OpenFOAM is built.
In .bashrc file, I have this line:
alias of201='source /Storage1/cfd/OpenFOAM/OpenFOAM-2.0.1/etc/bashrc foamCompiler=ThirdParty WM_COMPILER=Gcc45 WM_NCOMPPROCS=8'
Then I went to damBreak tutorial and decompose the case into 4 domains. Then I ran foamJob -p -s Test-parallel (parallel.txt) and also foamJob -p -s interFoam (error.txt).
2.> I ran foamInstallationTest. It does not show any error. (foamInst.txt)
3.>Before building openFOAM 2.0.1, I had openFOAM 1.6 installed on the cluster. In OpenFOAM 1.6 (openmpi-1.3.3 included in thirdparty-1.6 package), parallel runs were working smoothly without any error on master as well as on nodes.
So what can be the reason for parallel runs not working in OpenFoam-2.0.1?
Meanwhile, I came across this:
http://www.openfoam.com/mantisbt/view.php?id=296
Thanks
Hrushikesh
Old   February 20, 2012, 12:12
Bruno Santos
Indeed! I vaguely remember seeing the same here on the forum... about using Open-MPI 1.4.3 instead... Here we go: http://www.cfd-online.com/Forums/ope...s-openmpi.html
By the way, since you are using the alias method for activating OpenFOAM environments, you might be interested in the following bug report for when using foamJob: http://www.openfoam.com/mantisbt/view.php?id=231 - the pertinent file is this: patch4foamJob_send_settings_var
Good luck!
Bruno
Hrushi likes this.
Old   April 11, 2012, 13:59
Hi Bruno,
I did managed to get the OpenFOAM 2.0.1 and 2.1.0 running in parallel mode (with OpenMPI 1.4.1) on a single node of the cluster using foamJob as well as mpirun command.
But I am not been able to float the runs on multiple nodes.
log file:
/Storage1/cfd/OpenFOAM/OpenFOAM-2.0.1/bin/foamExec: line 145: exec: interFoam: not found
Can this be because OpenFOAM environment is not active on other nodes? I usually log onto the node, activate the OF environment, then float the run.
What can be done about this?
Hrushikesh
Old   April 11, 2012, 16:35
Bruno Santos
Hi Hrushikesh,
Have you made the changes shown in this link: patch4foamJob_send_settings_var ?
If not or if you don't understand how to do them, run the following commands:
(echo export foamCompiler=ThirdParty; echo export WM_COMPILER=Gcc45; echo export WM_NCOMPPROCS=8)  > /Storage1/cfd/OpenFOAM/OpenFOAM-2.0.1/etc/prefs.sh
Or simply edit the file "/Storage1/cfd/OpenFOAM/OpenFOAM-2.0.1/etc/prefs.sh" and place in it the following lines:
Best regards,
Bruno
Hrushi likes this.
Old   April 13, 2012, 08:09
Hi Bruno,
Yup. That did the trick (patch4foamJob_send_settings_var).
Thanks for telling me g=how to do those settings.
Now I can run OpenFOAM on multiple nodes.
Hrushikesh
Old   April 13, 2012, 08:17
Hi Bruno,
Hrushikesh
Experience in building OpenFOAM on LinuxIA64 Nils Smeds (Smeds) OpenFOAM Installation 43 July 25, 2010 09:09
New building machine for OpenFoam gerbervdgraaf OpenFOAM Installation 23 December 9, 2009 02:39
Building OpenFOAM on IRIX lakeat OpenFOAM Installation 7 July 16, 2008 07:27
Building OpenFOAM 13 on solaris10Sun Opteron AMD64 phil OpenFOAM Installation 0 August 28, 2006 01:12
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 09:27
