January 2, 2019, 00:07 |
BlockMesh limitations
Raj Kiran
Rep Power: 7 |
Hello Foamers,
I have a domain of (28*2*2.57) (m*m*m) and my very small working component in the domain. The problem is when am trying to discretise the domain (200 2800 257) , it is giving me an error of running out of memory. When i reduce the discretisation (100 280 128) , it is killing the process after sometime. I couldn't figure out what's the problem. I need blockMesh for snappyHexMesh. Attached is my blockMesh file. Thanks & Regards in advance. |
[blockMesh] blockMesh coordinate system | pardoa | OpenFOAM Meshing & Mesh Conversion | 5 | October 23, 2023 13:29 |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
