[snappyHexMesh] Meshing a diffuser using snappyhex problem?
Old   July 11, 2015, 07:16
Default Meshing a diffuser using snappyhex problem?
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Foamers,
I hope that you all are well. I am new to openFoam. I am trying to mesh a diffuser inside a cube. I have created the stl file using solidworks and made sure that the diffuser is inside the blockMesh for the file that I have created using paraview. I have changed the patches inside the snappyhexmesh file to match the stl file. Furthermore, I have applied the following commands:
1- blockMesh
3- decompserdec
3- mpirun -np 6 snappyHexMesh -overwrite -parallel
4- reconstructParMesh -constant
So far, I am unable to get any results. Please if anyone could find sometime to help me out in this regard.
Thanks in advance,
http://www.mediafire.com/download/3t...ffuser1.tar.gz
tareqkh is offline   Reply With Quote
Old   July 12, 2015, 03:21
Default Anybody have some time
tareqkh's Avatar
CFD
I have tried but noting has happened up until now...
3D Cyclone meshing problem Wayne12195 Mesh Generation & Pre-Processing 0 September 25, 2018 01:45
[ANSYS Meshing] problem in meshing of Aerofoil shaped obstacles in plane channel. lohith ANSYS Meshing & Geometry 0 June 20, 2018 02:58
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) fluent_beiyo ANSYS Meshing & Geometry 8 April 26, 2014 04:55
[ICEM] Meshing problem in Formula one Far ANSYS Meshing & Geometry 113 April 23, 2013 12:36
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 11:27
