Grid Independence problem
Like Tree1Likes
  • 1 Post By wyldckat
Old   May 20, 2013, 16:37
Default Grid Independence problem
immortality's Avatar
Ehsan
immortality is on a distinguished road
In the case I'm running I changed the mesh(350*20 the original like a shock tube case) and fined the grid(690*40)to and although the residuals are the same,but the values of variables change even I fined grid more(to 1040*60) and to(1380*80) but the values changed again.
now the speed of run has become very low and I don't know if it will reach to constant results that not change with mesh anymore or not and till when can continue. because the results in assigned time(for example 1.2e-5s) are increasing their differences how much I move ahead.
I use rhoCentralFoam and it seems it doesn't have an internal loop in it.can it cause any problem?
the case is like shockTube but is 2D in grid that both smaller sides are moving walls that open and close to the environment(specified values for BC).
since its related to my thesis unfortunately I'm not allowed to put it here,but if there is any hint or advice I will be glad to hear(read)it!
thanks.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 20, 2013, 23:03
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I wouldn't say its safe to assume that any of the tutorial cases are physically accurate. They're tutorials in case setup not validation cases. Its not surprising that you are seeing grid dependence issues.
kmooney is offline   Reply With Quote
Old   May 21, 2013, 07:08
Ehsan
Hi dear Kyle
I'm changing the grid sizes and expect that the results change very low after reaching to a fine enough mesh,and also I have used my BC's.so I don't use the same tutorials but its similar and I originated it from shock tube case.i don't understand your meaning exactly.thank you for more clarification.
new:I have found it:http://www.cfd-online.com/Forums/flu...html#post95492
but why grid near the wall should not be changed?and how could do this in OpenFOAM?
Old   May 22, 2013, 15:01
Ehsan
its necessary to give more information now.
there is a simple rectangular geometry.then whats the approach to study grid independence.
1)does the mesh have to be uniform or non uniform in studying?
2)is it acceptable to fix one direction grid points and fine the mesh by only increase the other side mesh points?
hex (0 1 4 3 9 10 13 12) (500 50 1) simpleGrading (1 4 1)
    hex (1 2 5 4 10 11 14 13) (500 50 1) simpleGrading (1 4 1)
    hex (3 4 7 6 12 13 16 15) (500 50 1) simpleGrading (1 .25 1)
    hex (4 5 8 7 13 14 17 16) (500 50 1) simpleGrading (1 .25 1)
3)what should be "aspect ratio" in each of grids?generally is it require that the mesh be good enough in each step or not important in compare with increasing mesh points(each mesh quality isn't important by itself very much and its sufficient to be somewhat acceptable)?
4)how much change in variables(p,U,T) are acceptable in each step of refining mesh?
5)and generally say whats the approach and way somewhat in details like two questions above.
I want to use grid dependence study first for laminar case,so please guide through this way.
thanks.
Old   May 23, 2013, 04:59
Ehsan
Hi
I have found that all is because of a vortex.
when i fine the mesh,results change very much,because a vortex exists inside and when I fine mesh it shows its center pressure lower and lower.
how can overcome this situation?is the center pressure of vortex important to resolve better (and fine mesh for that) or not?
also when mesh is coarse it doesn't capture vortex at all.
left pic.)fine mesh
right pic.)coarse mesh(it doen't capture the vortex)
thanks.
Old   May 27, 2013, 18:18
Default criteria of independence
Ehsan
hi
I wonder that is there any criteria for grid independence?
Mean how much difference in variables is acceptable?
Whats the rule of thumb here generally and not case specific?
For example the percent of change of pressure should be around how much generally?
I appreciate all experiences of checking your case grid independence criteria and all advice are thanked.
Old   May 28, 2013, 18:12
Retired Super Moderator
Bruno Santos
Hi Ehsan,
Since you asked my opinion on this topic, here goes: this is one of those really complicated topics. Specially when it comes to CFD. I'm unfortunately not familiar with any literature on this topic, so this is all I'm able to comment on.
AFAIK, the standard procedure is to have experimental data for comparison. Then configure the mesh, the boundary conditions and the solver algorithms in a way that it's possible to recreate the original experiment. This usually also requires knowledge/understanding of the physical forces that are occurring in the experiment. Then figuring out what can be somewhat ignored, so that we don't need a mesh with 1e60 cells to accurately simulate the case
The problem becomes bigger when we do not have experimental data. AFAIK, this is when LES and DNS should be used, since these give the most accurate answers... although proper calibration of the mesh/BCs/solvers is a must. Then compare results with the RANS (OpenFOAM's RAS) executed case, to see what can be discarded and what can be used.
But if you're stuck with RANS only, then things get reaaaaally tricky. The finer the mesh is, the more characteristics you're able to get out of the simulation. For example, it's easy to find vortices, where none existed on a coarser mesh.
This then implies that you also have to take into account the configuration of the "fvSchemes" and "fvSolution", because the finer the mesh is, the more you probably will have to calibrate these parameters.
Then the turbulence model might become inaccurate, due to the finer mesh resolution... as I said, reaaaaally tricky
From what I can remember, there are at least two training/testing/validation cases that should be easily found:
  • The 2D case of the cylinder in the middle of a flow. There's tons of experimental data for various numbers of Reynolds, so it's a matter of running simulations to compare results.
  • The Ahmed body, which is an abstract vehicle shape, for which there should be some experimental data as well.
Either one of these cases could be used to help validate your own work, as well as give you more self-assurance on what you're doing for your thesis.
Best regards,
Bruno
immortality likes this.
grid independence dibya FLUENT 2 April 27, 2007 09:16
On grid independence David Chabot FLUENT 0 May 31, 2005 11:22
grid independence chanchala FLUENT 11 January 11, 2004 06:50
A doubt on grid independence study G.Balakrishnan FLUENT 4 November 21, 2000 11:05
nonstaggered grid problem Zhi-Xing Yu Main CFD Forum 7 August 26, 1998 13:22
