[snappyHexMesh] How to generete internal domain from snappyHexMesh?
Old   March 3, 2021, 00:36
Default How to generete internal domain from snappyHexMesh?
Sunag R A
sunagra27 is on a distinguished road
Dear All,
I have a set of 3D data points that looks similar to hemisphere. I converted these datapoints to traingulated surface using MeshLab and converted to stl file.
1. But, I need to close the bottom part of the domain as shown in the Image attached. I need to do internal heat transfer based on this domain. So, How to close the entire bottom surface so as to be used for simulation?
2. Alternatively, I tried working with blockmesh and snappyHexMesh thinking that the one surface of the blockmesh will covers the bottom surface of the stl mesh and give 3D internal mesh. Well, my idea was wrong. So, how to obtain only the internal domain along with closed surface at the bottom?
I have attached the images link for reference.
1. Surface reconstructed from meshlab
https://drive.google.com/file/d/13GJ...ew?usp=sharing
2. Bottom surface that need to be closed for further mesh and simulation
https://drive.google.com/file/d/1ClD...ew?usp=sharing
3. Mesh obtained with BlockMesh and SnappyHexMesh
https://drive.google.com/file/d/1FNZ...ew?usp=sharing
Any leads will be appreciated.
Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
blockmesh, internal, snappyhexmesh, stl, surface
Internal Patches from SnappyHexMesh twinturbotom OpenFOAM Pre-Processing 1 December 2, 2017 19:53
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
[snappyHexMesh] snappyHexMesh and blockMesh for internal flow (leaking geometry?) vaina74 OpenFOAM Meshing & Mesh Conversion 10 November 20, 2014 09:14
[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh denner OpenFOAM Meshing & Mesh Conversion 3 October 13, 2011 09:24
[snappyHexMesh] SnappyHexMesh fails with internal Zones chossfeld OpenFOAM Meshing & Mesh Conversion 1 January 27, 2011 08:29
