[Commercial meshers] multiplying diameters to 0.001 in a grid that has the .msh format
Like Tree2Likes
  • 1 Post By wyldckat
Old   May 1, 2013, 01:49
Default multiplying diameters to 0.001 in a grid that has the .msh format
Bobby
babakflame is on a distinguished road
Dear Buddies
Hi
I have created my 3d-grid in gambit software and then with the help of fluent software and fluentMeshToFoam directive, imported the grid to openfoam. Now, I have found that my diameters are in mm, instead of m; i.e. I need to multiply my diameters to 0.001 . Is there any way to do it now in OpenFOAM or I need to go back to gambit for the required modifications. In constant folder, there is a polymesh folder with some other sub folders.
Regards
Bobi
babakflame is offline   Reply With Quote
Old   May 1, 2013, 07:07
Retired Super Moderator
Bruno Santos
Greetings Bobi,
What you're looking for is transformPoints: http://openfoamwiki.net/index.php/TransformPoints
Best regards,
Bruno
babakflame likes this.
Old   May 2, 2013, 08:52
Bobby
Hi Bruno
Thanks for ur help , I am going to work with transformpoints to become familiar with it.
Regards
Bobi
Old   May 5, 2013, 06:47
Bobby
Dear Bruno
Hi
The -scale utility is used in the incompressible/pimpleFoam/elipsekkLOmega
I think I need to make a Allrun file.
Would you PLZ hint me that which lines from the aforementioned file in elipsekkLOmega is needed for me; cause I need to multiply dimensions by 0.002 i.e. (0.002 , 0.002 , 0.002)
The Allrun file in elipsekkLOmega is as:
PHP Code:
#!/bin/sh
cd ${0%/*} || exit 1    # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Get application directory
application=`getApplication`
runApplication blockMesh
transformPoints -scale '(1.6666 1 1)'
cp system/changeDictionaryDict.X system/changeDictionaryDict
runApplication changeDictionary -instance system
runApplication mirrorMesh
rm log.mirrorMesh
rm log.changeDictionary
cp system/changeDictionaryDict.Y system/changeDictionaryDict
cp -rf 0/polyMesh constant/
runApplication topoSet
runApplication createPatch -overwrite
runApplication $application
I am sure that I need the
PHP Code:
in the bash file, But what about other lines, are they necessary for me?
Regards
Bobi
Old   May 5, 2013, 07:10
Bruno Santos
Hi Bobi,
PHP Code:
Creating your own Allrun script is a good idea, since it'll make it easier for you to run the case more than one time.
From your description so far, it looks like you only need to transform the mesh points. Although, if you want to take advantage of the runApplication and runParallel functions, you'll need the following code at the top of the script:
#!/bin/sh
Best regards,
Bruno
[General] Paraview file format for collocated grid hadian ParaView 0 February 13, 2008 09:55
ON ICEM grid format Lee Main CFD Forum 2 February 27, 2006 18:53
Anyone know the format of this grid file? Pete Main CFD Forum 1 January 6, 2005 03:06
Grid Generator for Plot3d format Jens Bennetsen Main CFD Forum 0 September 12, 2000 05:00
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
