[snappyHexMesh] Blender and snappyHexMesh
Old   November 1, 2013, 08:13
Default Blender and snappyHexMesh
Hao
Hao Wang
Hao is on a distinguished road
Hallo all!
I am trying to go through a process that create an irregular object from Blender, convert it to STL file with ascii format, insert it into a channel on a slope, finally mesh it with SnappyHexMesh. But it seems that is not easy to be done?
Anyone have some tutorial case, better a video uploaded, I didn't find such thing on internet, but it will be cool if someone complete one! Wow! By the way, I simply download a Cup Blender object and converted it into STL file from Blender, but it cannot be open, not an ascii file. I also install the addons of SwiftBloc and SwiftSnap but didn't find them from the Blender interface. I am using Blender 2.68a, some ideas?
I wish you all the best!
Hao
Hao is offline   Reply With Quote
Old   November 2, 2013, 22:23
Nucleophobe is on a distinguished road
Hao,
I'm not sure I understand. Are you suggesting that you are unable to get snappyHexMesh (sHM) to read the STL file because the STL from Blender is a binary file?
sHM can read binary STL files, so this shouldn't be a problem. As far as I know, the only tricky part in what you are describing would be patch definition.
Nucleophobe is offline   Reply With Quote
Old   November 4, 2013, 17:55
Jace
zhengzh5 is on a distinguished road
Originally Posted by Hao View Post
Hallo all!
Hao
when you save .stl files in blender, there's an option for ascii format. (usually on the left side panel). Make sure you check that box.
zhengzh5 is offline   Reply With Quote
Old   December 11, 2013, 03:38
Ulf Aslak
ulfaslak is on a distinguished road
Dear Hao,
I got into the whole Blender -> swiftSnap -> sHM work flow by loosely following this guide. It's takes you through all the stages of structure design however there are a few things you need to be aware of if you aren't already.
1. swiftSnap must be enabled before you start to design (or import) your structure. Furthermore I have found it necessary to initially mark a feature line with a "Feat. level: x" where x can be any given level, in order to make the addon to do its job right.
2. set locationInMesh is very important, as sHM will otherwise mesh all the space around your structure, however not the actual structure. This is really annoying to realise upon inspection with paraView after a 15 minute meshing process.
There's much more that I struggled with when I was working out how to do this, and if you have any further questions, do not hesitate to ask.
I hope this is of any help,
Ulf
ulfaslak is offline   Reply With Quote
Old   December 11, 2013, 15:33
Originally Posted by ulfaslak View Post
Dear Hao,
I got into the whole Blender -> swiftSnap -> sHM work flow by loosely following this guide...
It looks like the link is dead. Can you repost this Ulf?
Old   December 11, 2013, 16:18
Ulf Aslak
Oh, sorry I must have moved around the files in my Dropbox folder. This one should work. https://www.dropbox.com/s/zalxjp6fkr...gInBlender.pdf
Old   May 9, 2014, 05:54
Daniel
dalas.revo is on a distinguished road
Dear Hao,
Ulf
Dear Ulf,
I am Daniel. I am all new to this topic, and so I would appreciate any help. I have to do the same workflow (Blender -> swiftSnap -> snappyHexMesh) and I am a little bit lost. I am looking for a nice guide which could take me through the first try.
I have to model a stove and got an stl file which I would like to mesh with blender/swiftsnap/shm.
Could you be so kind and repost the link?
Regards,
Daniel
dalas.revo is offline   Reply With Quote
SnappyHexMesh GUI add-on for Blender tkeskita OpenFOAM Pre-Processing 22 April 22, 2024 11:45
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Broken Mesh after doing snappyHexMesh using an STL file created using blender cfd_inquirer OpenFOAM Meshing & Mesh Conversion 0 July 21, 2016 10:09
FYI: SwiftSnap now can also export on Blender to enGrid wyldckat enGrid 0 October 6, 2013 10:35
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
