[blockMesh] cylinders and cones using blockMesh
Old   November 17, 2013, 10:40
Default cylinders and cones using blockMesh
Kevin Hernandez
chunky262 is on a distinguished road
I am new to OpenFOAM and have to use it for a college project of mine. I need to generate a shape, but so far blockMesh hasn't been generating the shape that I want probably because its not entered right.
I need to make a 3D machine part. it should look like a cylinder surrounded by two cones. fluid should be able to go through the cylinder and between the two cones and fall out the bottom to the atmosphere.
Right now I have all of the points connected by arc edges and have made the arc edges into walls. I made the volumes between the two cones and the cylinder into hexblocks.
I heard from my mentor that it might be possible to generate specific shapes instead of just plotting the points to those shapes. could I get some help on how to do that or why my generation isn't working. any suggestions would be helpful.
chunky262 is offline   Reply With Quote
Old   November 17, 2013, 11:51
Retired Super Moderator
Bruno Santos
Greetings Kevin and welcome to the forum!
My advice is that if you are having trouble using blockMesh manually, then try using SwiftBlock: http://openfoamwiki.net/index.php/Contrib/SwiftBlock
Good luck! Best regards,
Bruno
