[blockMesh] Geometries BlockMesh
Old   November 23, 2013, 18:31
Smile Geometries BlockMesh
cesarjets is on a distinguished road
How I can interstect to geometries in OpenFOAM. I mean if for instance I have a simple geometry, letś say a cube and I want to add a cylinder on one of the faces, would I have to edit the blockmesh dictionary?
Thanks, any help on this will be appreciated.
cesarjets is offline   Reply With Quote
Old   November 24, 2013, 08:12
Retired Super Moderator
Bruno Santos
Greetings cesarjets,
That is not an easy task to do with blockMesh. My advice, try using SwiftBlock: http://openfoamwiki.net/index.php/Contrib/SwiftBlock
Best regards,
Bruno
Old   December 13, 2013, 17:51
Greetings wyldckat;
Right thanks much for your reply. you think that maybe to design a geometry like this it would be even a bit easier to do it in a CAD software and import it as a STL file?
Thank you,
Old   December 15, 2013, 09:29
Bruno Santos
Hi cesarjets,
It all depends on your objective. blockMesh currently is not able to use STL files as vertex data for the surface mesh, so you'll have to rely on some other mesher to do the meshing for you.
The difference is that with blockMesh you have (almost) full control over how the mesh is created and therefore are able to do some dedicated meshes. This is useful for keeping the cell count to a minimum, and to keep out parasitical cells (really small and/or contorted cells), but it's a major pain to create manually and/or with SwiftBlock.
AFAIK, people usually go with the simpler solution and rely on a mesher to do the heavy lifting for them. It's easier this way in most of situations, but don't expect it to be too easy either!
Best regards,
Bruno
Old   December 16, 2013, 17:51
Hi wyldckat;
Well, yes you're right regarding blockMesh using STL files. I was not so clear. I mean STL files with SnappyMesh? I think it certainly can deal with STL files right?
Thanks much
Old   December 29, 2013, 19:40
Bruno Santos
Hi cesarjets,
Sorry for the late reply.
Yes, snappyHexMesh can certainly handle STL files. But make sure that the STL is good enough, by running OpenFOAM's surfaceCheck on the STL file.
A bit more on this topic: http://www.cfd-online.com/Forums/ope...d-surface.html
Best regards,
Bruno
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
Gambit - Virtual Geometries (Pro's & Con's) James Date FLUENT 3 August 11, 2003 15:46
