[snappyHexMesh] weird behaviour snappyhexmesh |
March 6, 2014, 17:37 |
Ferdinand Pfender
Rep Power: 12 |
hi everyone,
im getting to the end of my thesis and the time is short. so i take it short as well im meshing an stl file with BM and SHM. its a tube with bifurcation and 2 outlets. the meshing is working fine up to one point: when i change the blockmesh to be finer, snappyhexmesh doesnt work any more: it doesnt cut the stl-file out of the blockMesh anymore. i attached snappy.log, blockMesh.log checkMesh.log snappyhexmeshdict and blockmeshdict. it would be gorgeous if somebody could help me, i got some big cases to run threw the weekend. Thanks a lot! ferdi |
March 7, 2014, 02:08 |
Akshay Kumar
Rep Power: 15 |
The issue might come from the resolution of your STL file... Where did you create the STL model? Try reducing the tolerance while writing the STL data and check
March 7, 2014, 08:38 |
Ferdinand Pfender
Rep Power: 12 |
hello akshay,
thanks for your answer! i solved the problem with exporting the stl file in more seperated parts and changing the SHM-option mergeTolerance from 1e-6 to 1e-7 |
Weird behaviour of pointMotionU and cellMotionU in dynamic mesh | rcastilla | OpenFOAM Running, Solving & CFD | 2 | June 8, 2016 03:14 |
[snappyHexMesh] snappyHexMesh does weird stuff sometimes | louay-tud | OpenFOAM Meshing & Mesh Conversion | 0 | April 5, 2016 03:36 |
Velocity weird behaviour | cinclus | FLUENT | 0 | April 1, 2015 00:45 |
Weird Behaviour | Michael-STM | FLUENT | 4 | March 14, 2014 13:15 |
twoPhaseEulerFoam - weird behaviour | grjmell | OpenFOAM Running, Solving & CFD | 5 | May 22, 2012 04:07 |
