[Other] dynamicMeshDict Error (OscillatingInletACMI2D)
Old   February 26, 2014, 21:18
Question dynamicMeshDict Error (OscillatingInletACMI2D)
Francis
afrotimy is on a distinguished road
Hi FOAMers,
Please, I am having a problem running the OscillatingInletACMI2D tutorial with pimpleDyMFoam.
With the already created case file, checkMesh and dynamicMeshDict error arose.
a) checkMesh Error:
Create time
--> FOAM FATAL ERROR:
No times selected
From function checkMesh
in file db/Time/timeSelector.C at line 263.
FOAM exiting
b) dynamicMeshDict error while running pimpleDyMFoam:
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function oscillatingLinearMotion
Applying solid body motion to cellZone inlet
Unable to find cellZone inlet. Valid celLZones are:0()
From function solidBodyMotionFvMesh::solidBodyMotionFvMesh(const IOobject&)
in file solidBodyMotionFvMesh/solidBodyMotionFvMesh.C at line 107.
FOAM exiting
Does anyone have an idea what is going on? I have tried to check the blockMeshDict also.
Francis.
afrotimy is offline   Reply With Quote
Old   March 1, 2014, 07:44
Retired Super Moderator
Bruno Santos
Greetings Francis,
Originally Posted by afrotimy View Post
a) checkMesh Error:
No times selected
You need to run with the "-constant" option:
checkMesh -constant
The cellZone named "inlet" does not exist. This is likely because it was not created yet with setSet or topoSet or some other utility.
I can now see that you're referring to the tutorial "incompressible/pimpleDyMFoam/oscillatingInletACMI2D" in OpenFOAM 2.3... did you run the script Allrun? Or are you at least following the steps described in the Allrun and Allrun.pre scripts?
If you don't know yet, the scripts present in the local folder can be executed, for example, like this:
./Allrun
Best regards,
Bruno
Old   March 17, 2014, 08:27
Francis
Okay thank you. I will try this means and feed you back.
Including run time as variable in dynamicMeshDict RKyle OpenFOAM Pre-Processing 4 March 26, 2023 00:39
dynamicMeshDict lsb1292 OpenFOAM Running, Solving & CFD 0 November 29, 2017 06:30
Difference between dynamicMeshDict - dynamicMeshDict.sixDoF Marc Batlle OpenFOAM Pre-Processing 1 August 16, 2017 11:50
I can't understand the moving function of "libfvMotionSolver.so" in dynamicMeshDict Jung hoo OpenFOAM Programming & Development 0 July 13, 2016 03:36
two (rival) dynamicMeshDict & objectRegistry (??) codder OpenFOAM Running, Solving & CFD 1 January 27, 2014 22:16
