November 26, 2014, 08:24 |
FeatureEdges with Blender
Tobias Holzmann
Rep Power: 51 |
Hi all,
here is a very simple workflow for all those who what to modify their featureEdgeMesh for snapping. Sometimes it happens that the *.eMesh which is generated by surfaceFeatureExtract is not very nice. Then you have to check and test and repeat it till you know, the result you want is not reachable or its done after a few runs. If you are familiar with that tool, the triangulation of STL's its very easy to produce good featureEdges with surfaceFeatureExtract. But if you want to generate your own one in a very simple way using blender, you have to do the following:
Have Fun
Keep foaming, Tobias Holzmann |
SnappyHexMesh GUI add-on for Blender | tkeskita | OpenFOAM Pre-Processing | 22 | April 22, 2024 11:45 |
[snappyHexMesh] Blender and snappyHexMesh | Hao | OpenFOAM Meshing & Mesh Conversion | 6 | May 9, 2014 05:54 |
FYI: SwiftSnap now can also export on Blender to enGrid | wyldckat | enGrid | 0 | October 6, 2013 10:35 |
blender to engrid | Astarta | enGrid | 1 | May 23, 2011 15:37 |
[blockMesh] Tool Block generation with blender | wikstrom | OpenFOAM Meshing & Mesh Conversion | 8 | August 12, 2009 17:09 |
