[snappyHexMesh] detached faces on inclined planes
Old   December 5, 2014, 16:24
Default detached faces on inclined planes
Diego
n719z is on a distinguished road
Greetings,
While trying to set up external aerodynamic simulations using snappy
I noticed that my wing surfaces were turning out bumpy.
After playing with simpler geometries a bit, I isolated this very
simple case that exercises such bad behavior: a tilted box inside
a blockMesh-ed wind tunnel. If I don't add boundary layers the
bumps are stuck to the box. Here with three boundary layers you
can see them flying above the surface of the box on the left edge
(also along the front edge, but those are more difficult to spot).
I'm wondering if I'm doing something obviously wrong, or is
this likely to be a bug in snappy?
Best,
--diego
n719z is offline   Reply With Quote
Old   December 6, 2014, 20:35
Diego
Update: false alarm, I am now fairly certain this is actually a bug in paraview.
When I run the flow, the detached patches don't seem to act like a wall, so the
parsimonious explanation would be that paraview erroneously assigns some of
the internal mesh faces to the patch.
Old   December 7, 2014, 16:08
Retired Super Moderator
Bruno Santos
Greetings Diego and welcome to the forum!
Just a quick question/answer - Try following the instructions given here: http://openfoamwiki.net/index.php/FA...is_in_ParaView - if following those instructions you still see these floating triangles, then you might want to check with checkMesh to see if the mesh is sane or not:
checkMesh -allGeometry -allTopology
Best regards,
Bruno
Old   December 11, 2014, 21:18
Diego
Thanks for the tips Bruno. You were right of course, the mesh ended up broken
after layer addition.
I have since turned my attention to cfMesh and am getting beautiful boundary layers
this way but the simpleFoam solver tends to blow up with these meshes even with no
boundary layers. If you can offer any clues to why this might be, please do!
Thanks,
Diego
Old   December 13, 2014, 16:19
Bruno Santos
Hi Diego,
Originally Posted by n719z View Post
but the simpleFoam solver tends to blow up with these meshes even with no boundary layers. If you can offer any clues to why this might be, please do!
Uh... OK, here's a clue: 42
Yes, it's a clue
But a better answer is this - Please follow these instructions: http://www.cfd-online.com/Forums/ope...-get-help.html
Best regards,
Bruno
Old   December 14, 2014, 00:43
Diego
Yup, after some more wrestling with it I finally broke down and uploaded entire case directories to this thread:
http://www.cfd-online.com/Forums/ope...tml#post523737
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
