[snappyHexMesh] snappyHexMesh & triSurface error
Old   December 14, 2014, 16:27
Default snappyHexMesh & triSurface error
a_habib's Avatar
Ahmad Habib
a_habib is on a distinguished road
I'm having a problem with snappyHexMesh, It's not using the triSurfaces and there is no cells to remove, it types these in the very begging:
Not all entries in refinementSurfaces dictionary were used. The following entries were not used : 1(cylinder.stl)
and
Not all entries in refinementRegions dictionary were used. The following entries were not used : 1(cylinder.stl)
And my *.stl file where made by SOLIDWORKS (ASCII format) in the first time and by FreeCAD (ASCII format) in the second one
the surface is closed (I cheked that) and in the center of the background mesh (I saw that in paraview) and have one patch named cylinder .. like this
solid cylinder
facet normal 0.998468 0.055333 0.000000
outer loop
vertex 0.198750 0.024106 0.065000
vertex 0.198750 0.024106 0.005000
vertex 0.166386 0.015976 0.069833
endloop
endfacet
endsolid cylinder
a_habib is offline   Reply With Quote
snappy hex mesh, stl
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
