[blockMesh] Creating similar multiplte geomentry by m4
Old   March 13, 2015, 04:44
Default Creating similar multiplte geomentry by m4
Warning
range_rover is on a distinguished road
Hey Foamers
I am trying to develop an m4 blockMeshDict script for 15 similar pipes attached to each other, if i start writing co ordinates and building blocks it may take lots of time.i have attached the geomentry below.
Is there any command in m4 or example where we can repeat the blocks of same dimensions repeatedly.
please do reply
Thanks in advance
range_rover is offline   Reply With Quote
Old   March 21, 2015, 08:52
Retired Super Moderator
Bruno Santos
Greetings range_rover,
In the m4 manual: http://www.gnu.org/software/m4/manual/m4.html - check the section "Conditionals, loops and recursion".
AFAIK, there is no example available in public for doing what you're asking for. Nonetheless, it feels like it would be better for you to use an easier programming language for creating the final dictionary file. Have a look at the list of examples provided here: http://openfoamwiki.net/index.php/Bl...MeshDict_files
Using Python or MATLAB might be the easiest solutions.
Best regards,
Bruno
Old   March 23, 2015, 03:35
Warning
thnks bruno for your help and advice,
are there any examples of developing Matlab scripts for openfoam ?
Old   March 28, 2015, 16:01
Bruno Santos
Hi range_rover,
The only example I know about for MATLAB is already listed on the wiki page and is this one: http://www.cfd-online.com/Forums/ope...blockmesh.html
Best regards,
Bruno
blockmeshdict block mesh, gnu m4, openfoam
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Heat Sink Meshing Olds88 Pointwise & Gridgen 14 June 20, 2016 07:11
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Problems running laminarSmoke r08n OpenFOAM Running, Solving & CFD 1 September 27, 2013 19:27
