[blockMesh] blockMesh crash with sigFpe
Like Tree2Likes
  • 1 Post By wyldckat
  • 1 Post By Mojtaba.a
Old   December 6, 2015, 12:24
Question blockMesh crash with sigFpe
hamide hayati
hamide is on a distinguished road
hello friends
i wanna block a simple geometry!!! but i face to a problem, it's:
Create time
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::Time::readDict() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::Time::setControls() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::Time::Time(Foam::word const&, Foam::argList const&, Foam::word const&, Foam::word const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/blockMesh"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
i don't know what the problem is!!!
would you please help me?
hamide is offline   Reply With Quote
Old   December 6, 2015, 13:01
Retired Super Moderator
Bruno Santos
Quick answer: Not enough information to diagnose the origin of the problem. Please follow the instructions given on this thread: http://www.cfd-online.com/Forums/ope...-get-help.html
edit: What you need to do is provide more details about how you got the error in the first place. For example: What is the content of the file "blockMeshDict" that resulted in that crash?
Old   December 7, 2015, 05:15
hamide hayati
this is my blockMeshdict:
|  \\    /   O peration     | Version:  2.2.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (0 0 0)
    (0.4 0 0)
    (0 0.02 0)
    (0.4 0.02 0)
    (0 0 -0.01)
    (0.4 0 -0.01)
    (0 0.02 -0.01)
    (0.4 0.02 -0.01)
blocks
    hex (0 1 3 2 4 5 7 6) (100 5 1) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 2 6 4)
    outlet
         type patch;
         faces
             (1 3 7 5)
    wall
        type wall;
        faces
            (0 4 5 1)
            (2 6 7 3)
    frontAndBack
        type empty;
        faces
            (0 2 3 1)
            (4 6 7 5)
mergePatchPairs
Last edited by wyldckat; December 7, 2015 at 06:24. Reason: Added [CODE][/CODE] markers
Old   December 7, 2015, 06:35
Bruno Santos
Greetings Hamide,
I've gotten a very different result from the one you reported:
Build  : 2.2.0-5be49240882f
Exec   : blockMesh
Date   : Dec 07 2015
Time   : 11:25:55
Host   : "machine"
PID    : 14207
Case   : /home/ofuser/OpenFOAM/ofuser-2.2.0/run/hamide/cavity
nProcs : 1
Create time
Creating block mesh from
    "/home/ofuser/OpenFOAM/ofuser-2.2.0/run/hamide/cavity/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM Warning :
    From function cellModel::mag(const labelList&, const pointField&)
    in file meshes/meshShapes/cellModel/cellModel.C at line 128
    zero or negative pyramid volume: -1.33333e-05 for face 0
--> FOAM Warning :
    zero or negative pyramid volume: -1.33333e-05 for face 1
--> FOAM Warning :
    zero or negative pyramid volume: -1.33333e-05 for face 2
--> FOAM Warning :
    zero or negative pyramid volume: -1.33333e-05 for face 3
--> FOAM Warning :
    zero or negative pyramid volume: -1.33333e-05 for face 4
--> FOAM Warning :
    zero or negative pyramid volume: -1.33333e-05 for face 5
--> FOAM Warning :
    From function blockMesh::createTopology(IOdictionary&)
    in file blockMesh/blockMeshTopology.C at line 255
    negative volume block : 0, probably defined inside-out
Check topology
  Basic statistics
    Number of internal faces : 0
    Number of boundary faces : 6
    Number of defined boundary faces : 6
    Number of undefined boundary faces : 0
  Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
Writing polyMesh
Mesh Information
  boundingBox: (0 0 -0.01) (0.4 0.02 0)
  nPoints: 1212
  nCells: 500
  nFaces: 2105
  nInternalFaces: 895
Patches
  patch 0 (start: 895 size: 5) name: inlet
  patch 1 (start: 900 size: 5) name: outlet
  patch 2 (start: 905 size: 200) name: wall
  patch 3 (start: 1105 size: 1000) name: frontAndBack
End
The problem is that the order of the vertices is incorrect. Please study the OpenFOAM User Guide in more detail. You can find the location of the PDF file if you run this command:
echo $WM_PROJECT_DIR/doc/Guides-a4/UserGuide.pdf
The other possibility is for you to install OpenFOAM 3.0.0, because that version allows for any order of the vertices.
Best regards,
Bruno
Old   December 7, 2015, 08:48
hamide hayati
thank you very much
but i cant understand what you mean!!!!
do you mean i should make the finer mesh?
i don't know how improve it!!!!!!
Old   December 7, 2015, 08:55
hamide hayati
and the other problem is:
i'm new in openFoam. i just can run it's tutorial and change them according to my need...
i can block this geometry in pisoFoam algorithm tutorial but not in the simpleFoam!!!!!
the error i sent you was in simpleFoam algorithm tutorial
Old   December 7, 2015, 12:38
Bruno Santos
Hi Hamide,
I mean that the problem is explained in section 5.3 in the User Guide: http://cfd.direct/openfoam/user-guide/blockMesh/
The problem you have is with the way the vertices are ordered:
vertices
    (0 0 0)
    (0.4 0 0)
    (0 0.02 0)
    (0.4 0.02 0)
    (0 0 -0.01)
    (0.4 0 -0.01)
    (0 0.02 -0.01)
    (0.4 0.02 -0.01)
And also the way they are ordered in the "faces" lists. For example, one of the problems could be this:
        faces
            (0 2 6 4)
The problem might be that the correct order is possibly "(4 2 6 0)", but I don't know if that is the solution or not.
Have you studied the 3 tutorials from the User Guide? See here: http://cfd.direct/openfoam/user-guide/tutorials/
Then you should take one step at a time. One small change and then test. Practice with each tutorial case. Learn how each detail works. Only then you should try and change to another tutorial.
Best regards,
Bruno
hamide likes this.
Old   December 13, 2015, 13:51
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
As wyldcat said you have to be careful with vertices order. I have completely taught the basics of blockMesh using the famous cavity problem OF in here.
If you had any other questions, you may ask here to get more detailed answers.
Soon there will be a Persian book out regarding "Meshing in OpenFOAM".
Best.
hamide likes this.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
reactingFoam sigFPE crash WiIIWiII OpenFOAM Running, Solving & CFD 0 April 21, 2018 10:11
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
