[CGNS] Convert Blockmesh into CGNS
Old   January 4, 2016, 15:20
Question Convert Blockmesh into CGNS
Massachusetts
kayla1994 is on a distinguished road
is it possible to convert a mesh blockmeshdict mesh in CGNS format? if yes, how?
Thanks for help
kayla1994 is offline   Reply With Quote
Old   January 5, 2016, 03:03
akidess's Avatar
Anton Kidess
Run blockMesh, then covert the mesh with the foamToCGNS utility.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   January 6, 2016, 05:53
Massachusetts
Primarily thanks for your answer
I tried making this procedure with the testcase present in the folder tutorial/basic/potentialfoam/cylinder.
I run the command "blockMesh" by terminal and then "foamToCGNS", but it gives me this error: "command not found".
Maybe the procedure i followed is not correct
Where do i make a mistake?
thanks
Old   January 7, 2016, 03:53
akidess's Avatar
Anton Kidess
foamToCGNS is a user contributed addon - you will have to install it first:
http://www.cfd-online.com/Forums/ope...available.html
You will need to spend some time and effort to get it to run with the official OpenFOAM release I think.
Cannot convert CGNS to SU2 native mesh paulzhang SU2 0 August 30, 2016 23:22
Convert 2d, diagonalized, unstructured grid to structured -- CGNS jgrisham Main CFD Forum 1 May 16, 2014 18:26
How to convert msh to cgns XXLRay Main CFD Forum 1 November 29, 2011 08:54
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS kamran_kibria ANSYS Meshing & Geometry 0 September 15, 2011 05:14
export or convert gambit mesh to CGNS zaidun FLUENT 6 April 20, 2006 04:48
