[Commercial meshers] Mesh export from fluent to openfoam: weird error messages |
January 30, 2016, 13:15 |
Prasanna Welahettige
Rep Power: 10 |
HAI,
Why i'm getting this kind of message when fluet mesh to export to openfoam ? Code:
+}[Embedded blocks in comment or unknown: Embedded blocks in comment or unknown:� Found end of section in unknown:/ Found end of section in unknown:? ��|���Embedded blocks in comment or unknown:� mbedded blocks in comment or unknown:� Found end of section in unknown:� )�@Embedded blocks in comment or unknown:� �@�\)��Embedded blocks in comment or unknown: Found end of section in unknown:� Embedded blocks in comment or unknown:� Embedded blocks in comment or unknown: Embedded blocks in comment or unknown: �,Embedded blocks in comment or unknown:�� �Embedded blocks in comment or unknown:� Embedded blocks in comment or unknown: Embedded blocks in comment or unknown:� Embedded blocks in comment or unknown:� �Embedded blocks in comment or unknown: Embedded blocks in co Last edited by wyldckat; January 31, 2016 at 13:23. Reason: Added [CODE][/CODE] markers |
January 31, 2016, 13:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Depends on the format version of your Fluent mesh and it also depends on the version of OpenFOAM you are using.
Those messages can either be ignored or are already fixed in one of the more recent versions of OpenFOAM. Either way, please provide a simple example Fluent mesh so that we can reproduce the same error message.
January 31, 2016, 16:21 |
Rep Power: 10 |
Thank you for replying.
This is gas - gas mixing model. Using Fluent version 16.2. Openfoam version 2.4.0. I have changed the boundary condition according to fluent mesh. But still openfoam can not run the fluent mesh. What can be the reasons ? |
January 31, 2016, 16:29 |
Bruno Santos
Rep Power: 128 |
Quick answer: Unfortunately you haven't provided enough information to diagnose the problem.
Please follow the steps written here: http://www.cfd-online.com/Forums/ope...-get-help.html - this way it will be easier to diagnose the problem. Otherwise, you're asking for us to guess what the problem is out of more than 1000 possible reasons as to why your case is not working on OpenFOAM . |
February 4, 2016, 06:25 |
Corant number mean rising - problem.
Rep Power: 10 |
Hai,
Now I have this issue corant number rising continuesly give error massege, I'm using icoFoam solver. following error massege comes, what can be the reasons ? Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : icoFoam Date : Feb 04 2016 Time : 12:11:05 Host : "meeseeks-Precision-Tower-7810" PID : 3746 Case : /home/meeseeks/prasa/run/model3 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 5e-05 Courant Number mean: 6.71136e-05 max: 0.0518149 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 1.38584e-06, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 5.94309e-06, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 7.70462e-07, No Iterations 164 time step continuity errors : sum local = 1.03434e-10, global = 2.72659e-12, cumulative = 2.72659e-12 DICPCG: Solving for p, Initial residual = 0.00784595, Final residual = 9.57557e-07, No Iterations 124 time step continuity errors : sum local = 2.06591e-08, global = 2.60165e-10, cumulative = 2.62891e-10 ExecutionTime = 0.73 s ClockTime = 1 s Time = 0.0001 Courant Number mean: 0.0151534 max: 0.374485 smoothSolver: Solving for Ux, Initial residual = 0.606285, Final residual = 9.33117e-07, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.13063, Final residual = 7.57316e-06, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.332338, Final residual = 8.93221e-06, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.142013, Final residual = 8.82601e-07, No Iterations 143 time step continuity errors : sum local = 2.16199e-08, global = -6.83841e-11, cumulative = 1.94507e-10 DICPCG: Solving for p, Initial residual = 0.0453243, Final residual = 8.11834e-07, No Iterations 131 time step continuity errors : sum local = 7.20617e-09, global = -2.82476e-11, cumulative = 1.6626e-10 ExecutionTime = 1.08 s ClockTime = 1 s Time = 0.00015 Courant Number mean: 0.0158302 max: 0.561537 smoothSolver: Solving for Ux, Initial residual = 0.181653, Final residual = 6.75105e-07, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.0507999, Final residual = 2.53766e-06, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.249424, Final residual = 8.27343e-07, No Iterations 3 DICPCG: Solving for p, Initial residual = 0.522183, Final residual = 9.40058e-07, No Iterations 140 time step continuity errors : sum local = 5.53735e-09, global = 9.29897e-12, cumulative = 1.75559e-10 DICPCG: Solving for p, Initial residual = 0.10772, Final residual = 7.87431e-07, No Iterations 128 time step continuity errors : sum local = 1.57164e-09, global = 2.80607e-11, cumulative = 2.03619e-10 ExecutionTime = 1.42 s ClockTime = 1 s Time = 0.0002 Courant Number mean: 0.0157345 max: 0.557623 smoothSolver: Solving for Ux, Initial residual = 0.0260866, Final residual = 3.24105e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00990692, Final residual = 6.46839e-07, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.0538437, Final residual = 2.93782e-06, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.349896, Final residual = 9.11121e-07, No Iterations 139 time step continuity errors : sum local = 1.33925e-09, global = -1.13943e-11, cumulative = 1.92225e-10 DICPCG: Solving for p, Initial residual = 0.0431763, Final residual = 8.98031e-07, No Iterations 132 time step continuity errors : sum local = 9.07484e-10, global = -2.82289e-11, cumulative = 1.63996e-10 ExecutionTime = 1.76 s ClockTime = 2 s Time = 0.00025 Courant Number mean: 0.0157019 max: 0.550726 smoothSolver: Solving for Ux, Initial residual = 0.0120567, Final residual = 2.41214e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00481902, Final residual = 6.04422e-07, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.0239811, Final residual = 9.86613e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.190656, Final residual = 8.03269e-07, No Iterations 136 time step continuity errors : sum local = 7.23939e-10, global = -1.28889e-13, cumulative = 1.63867e-10 DICPCG: Solving for p, Initial residual = 0.0155782, Final residual = 9.49934e-07, No Iterations 125 time step continuity errors : sum local = 7.76001e-10, global = -1.30238e-11, cumulative = 1.50843e-10 ExecutionTime = 2.08 s ClockTime = 2 s Time = 0.0003 Courant Number mean: 0.0156726 max: 0.654244 smoothSolver: Solving for Ux, Initial residual = 0.00879693, Final residual = 1.94545e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00383515, Final residual = 6.77615e-07, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.0171416, Final residual = 6.29931e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.116409, Final residual = 8.701e-07, No Iterations 134 time step continuity errors : sum local = 6.62414e-10, global = 2.8479e-13, cumulative = 1.51128e-10 DICPCG: Solving for p, Initial residual = 0.00560623, Final residual = 9.80388e-07, No Iterations 122 time step continuity errors : sum local = 7.07401e-10, global = 5.86687e-12, cumulative = 1.56995e-10 ExecutionTime = 2.4 s ClockTime = 2 s Time = 0.00035 Courant Number mean: 0.0156595 max: 0.870647 smoothSolver: Solving for Ux, Initial residual = 0.00727937, Final residual = 1.73164e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00348196, Final residual = 1.55832e-06, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.0140972, Final residual = 7.85586e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.0964285, Final residual = 7.90232e-07, No Iterations 135 time step continuity errors : sum local = 5.6033e-10, global = 5.53276e-12, cumulative = 1.62528e-10 DICPCG: Solving for p, Initial residual = 0.00281709, Final residual = 9.23352e-07, No Iterations 96 time step continuity errors : sum local = 6.50587e-10, global = -3.56866e-11, cumulative = 1.26841e-10 ExecutionTime = 2.69 s ClockTime = 3 s Time = 0.0004 Courant Number mean: 0.015657 max: 1.19054 smoothSolver: Solving for Ux, Initial residual = 0.00658232, Final residual = 2.7559e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00352735, Final residual = 3.16808e-06, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.0127143, Final residual = 6.00431e-06, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.111259, Final residual = 9.04817e-07, No Iterations 138 time step continuity errors : sum local = 6.60456e-10, global = 2.80977e-11, cumulative = 1.54939e-10 DICPCG: Solving for p, Initial residual = 0.00427442, Final residual = 7.9171e-07, No Iterations 127 time step continuity errors : sum local = 6.10697e-10, global = -2.55804e-12, cumulative = 1.52381e-10 ExecutionTime = 3.02 s ClockTime = 3 s Time = 0.00045 Courant Number mean: 0.0156727 max: 1.75486 smoothSolver: Solving for Ux, Initial residual = 0.0066215, Final residual = 8.75173e-06, No Iterations 19 smoothSolver: Solving for Uy, Initial residual = 0.00425823, Final residual = 8.65799e-06, No Iterations 36 smoothSolver: Solving for Uz, Initial residual = 0.0124809, Final residual = 8.67935e-06, No Iterations 32 DICPCG: Solving for p, Initial residual = 0.166059, Final residual = 9.73893e-07, No Iterations 143 time step continuity errors : sum local = 8.89965e-10, global = 4.2187e-11, cumulative = 1.94568e-10 DICPCG: Solving for p, Initial residual = 0.0170893, Final residual = 9.57808e-07, No Iterations 137 time step continuity errors : sum local = 1.06481e-09, global = -2.37156e-11, cumulative = 1.70852e-10 ExecutionTime = 3.5 s ClockTime = 3 s Time = 0.0005 Courant Number mean: 0.0157411 max: 2.85948 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? at ??:? Floating point exception (core dumped) meeseeks@meeseeks-Precision-Tower-7810:~/prasa/run/model3$ ^C meeseeks@meeseeks-Precision-Tower-7810:~/prasa/run/model3$ P Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { pressure_outlet { type fixedValue; value uniform 0; } velocity_inlet_small { type zeroGradient; } velocity_inlet_large { type zeroGradient; } walls { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { pressure_outlet { type zeroGradient; } velocity_inlet_small { type fixedValue; value uniform (0 -15 0); } velocity_inlet_large { type fixedValue; value uniform (10 0 0); } walls { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1; deltaT 0.00005; writeControl adjustableRunTime; writeInterval 0.01; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 1; maxAlphaCo 1; maxDeltaT 1; // ************************************************************************* // Prasanna. Last edited by wyldckat; February 6, 2016 at 05:56. Reason: Added [CODE][/CODE] markers |
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case | DominicTNC | OpenFOAM Meshing & Mesh Conversion | 3 | November 22, 2017 09:19 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
BC in export from hyper mesh to fluent | hamid sharif | Main CFD Forum | 0 | November 30, 2011 13:20 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
