[mesh manipulation] MoveDynamicMesh. Intersection of walls ( 1 fixed, 1 moving) |
June 30, 2016, 07:41 |
M. Montero
Rep Power: 17 |
Hi all,
I want to apply a rotating movement of several degrees to a blade, but the blade is installed over a hub in a perpendicular way. The hub is fixed. If a move only the blade and the hub has a fixedValue 0, wrong cells are created at the intersection between the patches. There is a sharp change in the cell shape. Is there any BC for the hub where the mesh can be slightly modified in the first layers to accommodate the rotation? Can it be done in a different way? The point is to modify the mesh inside OpenFoam without the need to re-mesh the geometry using other programs. Best Regards |
HELP - Moving car simulation in fluent | Brad Wells | FLUENT | 7 | January 4, 2018 19:55 |
How to avoid walls in moving referance frame (MRF) | san | FLUENT | 5 | March 31, 2006 01:17 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 05:32 |
Display of Moving Walls | Thomas Huewener | FLUENT | 1 | June 16, 2000 12:15 |
Scale Problem and Moving Walls in PCube/TGrid/Fluent | Christian Tollschein | Main CFD Forum | 8 | September 17, 1999 13:01 |
