[Gmsh] Gmsh STL import error
Old   October 2, 2016, 15:57
Default Gmsh STL import error
me3840 is on a distinguished road
Hello all,
I'm trying to get Gmsh to read my STL file in so I can remesh it.
However, when I import it, Gmsh reports:
Info : Mesh is in binary format
Info : Swapping bytes from binary file
Error : No facets found in STL file for solid 0
Error : Error loading 'geom.stl'
However my STL file is not in binary format, it's in ASCII. I have tried running dos2unix and changed the 'solid' on the first line to 'xolid' as this thread suggests:
http://onelab.info/pipermail/gmsh/2009/004995.html
But it didn't change anything. Does anyone know what I should do?
me3840 is offline   Reply With Quote
Old   October 6, 2016, 14:11
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Originally Posted by me3840 View Post
Hello all,
Did you use consistent units when you create the stl file? Why don't you post what are you trying to mesh, so that we can help you.
Best,
tareqkh is offline   Reply With Quote
Old   October 6, 2016, 15:33
Yes, the units are consistent. The file is too big but attached is a piece of it which shows the same problem.
Old   October 6, 2016, 16:18
tareqkh's Avatar
CFD
I don't understand what you just send me? Why don't you dent the geometry?
Best,
Old   October 6, 2016, 21:38
That file is a compressed STL file. To decompress it you just need to run the command:
gunzip wing_TE.stl.gz
Old   October 6, 2016, 21:43
tareqkh's Avatar
CFD
I have opened using Salome and saw only a line. If you want people to help you, you need to provide good details.
Best,
Old   October 7, 2016, 07:54
Yes, it's just the trailing edge of the wing, it should not be very big. However if you import it to Gmsh, it gives the same error as the full geometry. It's small and easy, that's why I put it there instead of the whole plane.
What details are you looking for? I'm really not sure what else I can provide; I import my geometry and it gives that error. I import this smaller piece of it and it gives the same error.
Did you try importing that part I posted to Gmsh? Do you get the same error? The fact that it imports correctly to Salome indicates there's nothing wrong with the file.
Old   October 8, 2016, 18:44
tareqkh's Avatar
CFD
Why don't you draw the trailing edge in gmsh since you are going to mesh in gmsh already? I have done different problems in gmsh -2D, 3D etc. I can help you getting your problem solved.
Best,
Old   October 9, 2016, 08:34
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Your STL-file starts with space. Removing it seems to fix the problem.
Here is the Gmsh code, which decides that STL is binary (https://onelab.info/svn/gmsh/trunk/G...elIO_STL.cpp):
bool binary = strncmp(buffer, "solid", 5) && strncmp(buffer, "SOLID", 5);
So your space in the beginning of the file breaks everything.
alexeym is offline   Reply With Quote
Old   October 9, 2016, 20:52
Thanks alaexym. That seemed to work well. Not sure why there's a space in all of the lines, but it's easy enough to remove.
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
