[snappyHexMesh] SnappyHexMesh castellation stage creates hole in surface where mesh flows into domain
Old   August 30, 2017, 04:19
Default SnappyHexMesh castellation stage creates hole in surface where mesh flows into domain
Dav3dum is on a distinguished road
Hello all!
In my case when I try to mesh a geometry, the castellation stage can't find one of surface of the geometry correctly. On that surface some holes appear, and the mesh floats into the domain through the holes. However, when I check the stl file by surfaceCheck, it says it is not closed but when I open the generated .obj files the surface is closed where the problem occurs. I've attached a picture of the .stl surface and the meshed surface together.
To check if those holes responsible for this problem i've tried to tighten the domain (=reducing the domain length), and-as i expected-these holes were responsible for this problem.
For other similar geometries where the stl is also not closed, but during the meshing these holes don't appear, I get a decent mesh without inflows.
If you could help me out with this problem i'd appreciate that!
Yours sincerly,
David
Dav3dum is offline   Reply With Quote
meshing, snappy
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 09:26
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] how to mesh a domain splitted in two? aCFDuser OpenFOAM Meshing & Mesh Conversion 6 August 19, 2015 08:27
