[snappyHexMesh] SHM for meshing plane surface without morphological changes
Old   October 27, 2017, 08:32
Default SHM for meshing plane surface without morphological changes
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
Dear All:-
Using SHM, I made a different trials for meshing a plane compound surface which is formed from two different shapes. For example, a triangle bounded by a rectangle. However, no patch had been added to the blockMesh file after running SHM . My scenario for meshing was as follows:-
- Making a watertight stl cube such that its bottom surface is the compound surface.
- Making a stl for each of the constituents of that cube ( left, right, back, front, top, triangle, and triangle-off-rectangle).
-Making all the constituents as a patches with the suitable surface based refinement and the cub as a refinementRegion sub-dictionary for the castellatedMeshControls to make the required volumetric refinements.
-Making the background mesh box bigger than the cub.
Everything went well. However, after running, non of the mentioned patches is added to the background mesh ( in the blockMesh file) and no .eMesh file is produced for any patch, except for the triangle and its bound rectangle.
I appreciate any clue , comment and suggestion.
Thanks
alinuman15 is offline   Reply With Quote
[snappyHexMesh] SHM addLayers doesnt work on the small surface handicraft OpenFOAM Meshing & Mesh Conversion 4 October 5, 2018 03:50
Measure the surface of the faces of a triangulated cutting plane Pagoda OpenFOAM Post-Processing 3 August 20, 2018 09:51
[snappyHexMesh] sHM refinement away from surface nholt OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 14:36
Impinging free surface water jet on a flat plane NicoMa STAR-CCM+ 0 July 7, 2015 06:15
Contour Plot of a curved surface projected onto a flat plane Amp CFX 4 March 12, 2013 22:54
