[snappyHexMesh] Boundary layer issues
Old   August 23, 2018, 14:16
Default Boundary layer issues
Lucas Cabrera
CabreraLucas is on a distinguished road
Hello, foamers
I'm having trouble adding boundary layers to my mesh. I've been tinkering with the layer controls as well as reading related threads in here, but I wasn't able to create the boundary layer. I tried attaching my sHMDict, blockMeshdict and the outputs but it didn't let me, for some reason, so I've put them on pastebin.
sHM: https://pastebin.com/BSfdWWkv
blockMesh: https://pastebin.com/ub3iKxNC
layer output: https://pastebin.com/tvAqjd3t
Does anybody know what's wrong? Thanks in advance.
Lucas
CabreraLucas is offline   Reply With Quote
Old   August 25, 2018, 09:23
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello Lucas,
You already have alotof cells having pyramid volume less the 1e-13. Try to use a much smaller value for pyramid volume (may be like 1e-20). Also you are using relative size false. Are you sure your mesh cell size is in the same range?
Regards
mwaqas is offline   Reply With Quote
Old   August 25, 2018, 13:51
Lucas Cabrera
Hello! Thanks for the reply!
I was using "relativeSize True" before so I decided to try it the other way. My geometry is an aneurysm about 5cm long.
I tried out your suggestion and unfortunately it didn't yield any different results.
Here's the output: https://pastebin.com/theQhMTX
Also I have attached what a slice of my geometry looks like after snap, but before layers. (After I run with addLayers on i get that exact same result)
Regards,
Lucas
Old   August 25, 2018, 14:10
Muhammad Waqas
How is your mesh quality before adding layers with pyramid volume <1e-20. May be you can try with relative size true starting with one layer. If you like, you can upload your case here and I can try myself (I will be able to test on manday).
Regards
Old   August 25, 2018, 14:47
Lucas Cabrera
I've uploaded my case here: https://www.dropbox.com/s/1x24dhqtig...urysm.zip?dl=0
I ran checkMesh and it didn't give me any errors. I'll try changing other settings. Thanks for the help!
Old   September 5, 2018, 08:03
Çağatay Emre Ayhan
Cagatayemre is on a distinguished road
Use default meshQualityDict for castellation and snap.
Try to use following meshQuality settings for only 'layer generation process'
maxNonOrtho 180;
maxBoundarySkewness -1;
maxInternalSkewness -1;
maxConcave 180;
minVol 0;
minTetQuality -1e30;
minArea -1;
minTwist 0.002;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
Cagatayemre is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
boundary layer simulation : basic issues amol palekar Main CFD Forum 0 July 27, 2004 18:22
