[Gmsh] GMSH to OpenFOAM file conversion error (GmshToFoam) |
October 27, 2018, 14:10 |
Nikhil Bollimuntha
Rep Power: 7 |
https://drive.google.com/open?id=1I1...hBKktvUO2F89g8 I have imported a step file into Gmsh and meshed it and also defined the boundary surfaces as shown above. I saved the file as a .msh file and tried to use the gmshToFoam to convert this msh file to OpenFOAM format. The following error occurs: https://drive.google.com/open?id=1mS...ma1etcZJlYIKrw Really grateful for the help. Regards. Last edited by Nikhil Bollimuntha; November 25, 2018 at 11:33. |
November 24, 2018, 23:12 |
Robert
Rep Power: 7 |
I cannot see your error in the linked images (probably best to post it as text), but I think I know what the problem is, as I have solved it myself.
If you are using the newer version of Gmsh (e.g. 4.0+), the default export format for .msh files has changed. However, OpenFOAM's gmshToFoam expects the "legacy" "Version 2" format. You can export your meshes in the legacy format by adding the "-format msh2" flag (if you are exporting by command line), or by selecting Version 2 format when you attempt to export in the GUI via File > Export > ... Hope this helps! |
November 25, 2018, 11:35 |
Nikhil Bollimuntha
Rep Power: 7 |
Hi, I did save it as ascii-2 format but that isn't the problem, there seems to be something else. I updated the drive links so you can see the error (unable to post the text for some reason, please see if you can fix it).
Regards, Nikhil |
November 26, 2018, 00:19 |
Robert
Rep Power: 7 |
If I remember correctly, that is the exact error you get for using V4 format, when gmshToFoam expects V2. How are you exporting V2 format?
May 18, 2019, 08:29 |
Solution
Akshay Patil
Rep Power: 10 |
I had a similar issue and exporting using "export" Version 1 solved the problem for me. |
error, gmsh, meshing, openfoam |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
