[Commercial meshers] ICEM - Internal patch appears despite merging meshes |
December 21, 2018, 11:01 |
Rep Power: 7 |
I'm working on generating mesh using ICEM. I decided to create mesh by defining two areas and then merging them. (See the first picture) I done merging in ICEM, so I got merged outer patches e.g. inlet instead of inlet-far and inlet-close. But there is still a extra patch which should not be defined, named close, which should belong to internalMesh. (see the second picture) It's blocking the simulation because I failed to find boundary condition like "don't care about this" or to merge the patch into internalField. Does anybody have idea how to solve my problem? Thanks a lot, Krzysztof |
December 30, 2018, 13:08 |
Rep Power: 7 |
Would updating workbench change anything? Right now I'm using v16 and current version is 19
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 04:48 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
chtMultiRegionFoam Tutorial | m.nichols19 | OpenFOAM | 12 | September 9, 2010 11:56 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
